X brake handbrake.
- Smoggy
30 Mar 2012 18:07 #36618
by Smoggy
X brake handbrake. was created by Smoggy
Will be picking up my axles from Gazwell early next month. They are SJ reinforced axles with chromoly 4340 driveshafts/arb lockers front and rear. They have been adapted to fit a jimny and the rear has had a disc conversion from a ford granada. Gary said there is no connection for a handbrake to the rear discs. Instead he relies on an 'X brake' from the gearbox/transferbox. Does anyone know what this entails and how I can go about converting my handbrake to this system. Cheers in advance.
30 Mar 2012 19:02 - 08 Apr 2012 13:36 #36622
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Re: X brake handbrake.
2002 JLX Soft Top
Last edit: 08 Apr 2012 13:36 by dirtydogz.
The following user(s) said Thank You: Smoggy
- X-Eng Simon
31 Mar 2012 07:52 #36640
by X-Eng Simon
Replied by X-Eng Simon on topic Re: X brake handbrake.
Do you have an SJ Transfer box fitted? If not, it's not a bad modification as they appear to be stronger and give the option of a 'rocklobster' conversion.
If so, the brake just bolts on the back. You will need to obtain a drive flange. Sammi boxes came with a rear flange fitted as standard, otherwise a front one should fit. One or two people have just cut down the original drum to make a flange.
This post: BigJimny shows how to fit the cable end to the jimny lever.
Si
Si
- suzuki jimny fella
31 Mar 2012 18:35 #36656
by suzuki jimny fella
Replied by suzuki jimny fella on topic Re: X brake handbrake.
just go a lobster box for my jimny what can i do to get me one of these fitted what is to be moded
- X-Eng Simon
03 Apr 2012 07:14 #36806
by X-Eng Simon
Do you mean - How do you fit a Lobster box to a Jimny or How do I fit an X-Brake to a lobster box? Or both?
Si
Si
- Smoggy
03 Apr 2012 17:13 #36844
by Smoggy
Replied by Smoggy on topic Re: X brake handbrake.
Primarily the latter Si, but preferably both if poss
Cheers.
Cheers.
Time to create page: 0.147 seconds
