axle problems
- fatwelly
17 Jun 2010 19:29 #3647
by fatwelly
axle problems was created by fatwelly
hello
I am very new to this 4x4 thing
having some issues with axle leaking grease badly is there a easy way to fix this not sure what I need to replace
Also the wheel wobble at low speed is pretty bad any ideas would be great have adjusted the steering box which has made some difference
Second?
Have been given set of vitara spring will these fit on a jimny will it give a slight lift
many thanks if you can help
Second?
- jonplace
17 Jun 2010 19:45 - 17 Jun 2010 19:45 #3648
by jonplace
Replied by jonplace on topic Re:axle problems
king pin bearings can often be the cause of gunge leaking out of the swivel. jack the wheel off the ground, one hand on the top and one hand on the bottom give it a good wiggle to see if theres any play. even better if you can get someone else to do the wiggling while you look at the swivel joint you may see the whole hub wobble on the swivel. theres a 'how to' guide on here.
not sure about vitara springs on a jimny but i'd imagine they'd be to stiff for the jim as the vit is a heavier car.
get some spring spacers if you just want a cheap lift from bits4vits
Last edit: 17 Jun 2010 19:45 by jonplace.
- fatwelly
22 Jun 2010 16:29 - 26 Jun 2010 18:32 #3672
by fatwelly
Replied by fatwelly on topic Re:axle problems
many thanks have now ordered new king pin bearings
will be fitting them asap
got a full kit have now fitted them will need to change the diff oil as soon as possible
also have to change the discs as well
they have warped badly
Last edit: 26 Jun 2010 18:32 by fatwelly. Reason: update
26 Jun 2010 17:52 #3680
by kirkynut
Replied by kirkynut on topic Re:axle problems
Hi there,
Order some front axle oil seals too and some CV grease and Hylomar Blue sealant.
You will also want to drain your front diff oil so you may as well get some of that whilst your spending.
The problem with the kingpin bearings being worn has meant that the halfshaft has been moving excessively in the oil seal allowing the axle oil past, which has watered down your CV and front wheel bearing grease and made it gunge that you have seen to come out of the swivel seal.
So the chances are your oil seal has had it now and your CV and wheel bearing are lacking in grease.
The hylomar blue sealant will seal everything back up nicely when you put it back together but don't get it in the way of the seals that seal the vacuum for the free wheeling front hubs or it will clog it up and stop them from working!
Hope this helps and saves you having to do the job twice!
Time to create page: 0.158 seconds
