Screeching
26 Mar 2012 13:57 #36385 by maverick
Screeching was created by maverick
ON road and OFF road i have a nasty screeching noise that seems to be coming from my front axle.
It *only* makes this screeching noise when my front FW Hubs are engaged (aka 4x4 mode) and occurs when I'm in Hi or Low Box (2wheel drive or 4wheel drive).
I thought i had fixed it last week after replacing both sides on King Pins (top and bottom) and fitting new AVH FW Hubs ... but the screech is back.
The CV's, The Wheel Bearings all look perfect - and of course the King Pins are cos i just replaced them?
Ideas on what or why would be welcome.
Jalapeño, IISY?
  • darthloachie
26 Mar 2012 14:18 #36387 by darthloachie
Replied by darthloachie on topic Re: Screeching
bearing in the diff where the prop joins?
mines just gone on the rear
you can waggle the prop and the end of the diff output shaft moves
26 Mar 2012 14:19 #36389 by maverick
Replied by maverick on topic Re: Screeching
how easy (or HARD) is it to replace?
Jalapeño, IISY?
  • Paul4x4
26 Mar 2012 14:35 #36391 by Paul4x4
Replied by Paul4x4 on topic Re: Screeching
If there's a little play in the pinion bearings, you can tighten the nut that holds the prop shaft flange in place to fix it. But I don't believe that would cause the screeching noise...
  • darthloachie
26 Mar 2012 14:43 #36395 by darthloachie
maverick wrote: how easy (or HARD) is it to replace?
don't know yet - only broke it yesterday
  • mcjimny
26 Mar 2012 16:30 #36402 by mcjimny
Replied by mcjimny on topic Re: Screeching
The advice i got on here re: pinion bearing was to swap the whole diff as you have to set backlash etc in the diff after.
Time to create page: 0.103 seconds
