Help I have a knocking!!
- adam
- Visitor
19 Mar 2012 10:14 #35888
by adam
I just had a thought. See new photo attached! If I bend the 2 black arrows outwards surely the shock would lift shightly. I could bend it out and put washers in between or even not bother with the washes, it might be good to have a bit of play? :pinch:
Replied by adam on topic Re: Help I have a knocking!!
Attachment knocking_2012-03-19.jpg not found
- adam
- Visitor
19 Mar 2012 12:19 #35902
by adam
Would it matter if I just took my re locators off?
- adam
- Visitor
19 Mar 2012 19:26 #35957
by adam
Iv found the problem!!!!! I took off the bottom of the shock and found that there is no insert inside the rubber bush. So the bolt is M12 but the hole through the bush is bigger, shouldn't there be an insert? Where can I get one or do I have to buy a set of new bushes?
19 Mar 2012 20:06 - 19 Mar 2012 20:08 #35965
by dirtydogz
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Replied by dirtydogz on topic Re: Help I have a knocking!!
The insert is in a kit which you get with shock from new,you will need to buy new bushes from Bits4Vits or Jimnybits.
2002 JLX Soft Top
Last edit: 19 Mar 2012 20:08 by dirtydogz.
- adam
- Visitor
19 Mar 2012 20:19 #35977
by adam
Well that just my luck isn't it! :ohmy: I had trouble with my brake hoses so the garage fitted them for me, I thought there were some in the kit! Ok ill have a look, do they need to be pro comp or just what every jimnybits or bits4vits have? I think bits4vits have a choice of rubber or poly but iv heard poly are quite stuff plus I can't be bothered changing all, ill just change the back ones!!
19 Mar 2012 20:29 #35983
by dirtydogz
2002 JLX Soft Top
If you just need the back ones buy them from Jimnybits £4.25+vat each.
www.jimnybits.co.uk/shop/jimny/ring-moun...ck-bush/prod_43.html
Attachment roundbush2.JPG not found
2002 JLX Soft Top
- adam
- Visitor
27 Mar 2012 06:05 #36421
by adam
Thanks to Jimnybits my jimny is no longer knocking! :woohoo:
Thanks all for you input!!
Time to create page: 0.159 seconds
