Help I have a knocking!!
- adam
18 Mar 2012 18:15 #35812
by adam
Hi everyone. For a while now I have had a slight knocking from the back end. Then today while lanning :woohoo: I had both front windows down so I heard it even louder. When I got home I had a look and I have found it
attached is a photo of where my shock sits, when i push the car up and down the bottom of the shock tapps on the shock mount. It doesnt seem bad but Im just wondering whether over time it might become a problem. Has anyone else found this problem and is there a way of stopping it? The shocks are less than six mounths old so i cant see it being the bushes but what do you think? I also noticed something else which is nothing to do with this problem, well I guess its not any way. When I jack my back end up so the wheels are completely off the ground, I can wiggle the spring about slightly and just on one side, is this normal?? I have tried and even though it wiggles, it cant be wiggled enough to come out thank god :side: .
Any help would be good thanks
Help I have a knocking!! was created by adam
Attachment knocking.jpg not found
- adam
18 Mar 2012 18:21 #35814
by adam
Replied by adam on topic Re: Help I have a knocking!!
Attachment knocking_2012-03-18.jpg not found
- mcjimny
18 Mar 2012 18:45 #35816
by mcjimny
Replied by mcjimny on topic Re: Help I have a knocking!!
It sounds like there may have been enough play in there for the hole to wear and its now got enough room to knock? Although they're bushed iirc so same principle the bush must have worn, iirc i read somewhere of replacements.
As for the spring, i would say they're related. The slack in the bush is being taken up by the weight of the axle and freeing up just enough clearance for the spring to move?
- adam
18 Mar 2012 21:01 #35845
by adam
Mmmm you could be right but even if the bush had worn surly there isnt enough room to make the spring slack. I just had a thought on the spring thing, When I fitted the springs, I seem to remember one being easier to fit, Im assuming it was that one!
Do you think this is dangerous or just something anoying?
- mcjimny
18 Mar 2012 21:07 #35848
by mcjimny
Could it be a bit of Jimny lean if the loose spring is on the passenger side?
I would get the shock sorted asap. Anything loose will only get worse in my experience.
- wanderinstar
18 Mar 2012 21:26 #35852
by wanderinstar
Replied by wanderinstar on topic Re: Help I have a knocking!!
How about fitting polybushes, aren't they harder than rubber so less chance to wear.
Time to create page: 0.116 seconds
