king pin help
16 Mar 2012 17:35 #35658 by mlines
Re: king pin help was created by mlines
If you have fitted a Transfer Box then Kingpin Bearings should not be an issue.
There is a step by step guide on this website.
No special tools are needed.
The only tricky bit could be the removal of the old race which needs to be driven out with a hammer. Getting a purchase on the race in order to hit it is not easy.
I can do both of mine in an hour, but then I have had some practice. I would suggest that one side should take no more than a couple of hours from start to finish.
  • mcjimny
16 Mar 2012 17:48 #35659 by mcjimny
Replied by mcjimny on topic Re: king pin help
I've done mine twice now. I'm by no means a mechanic but my dad is and as a result i'm quite confident with the spanners. Using martins how to guide its so simple, i can do it now though without!
As martin says the hardest part is getting the race out, i use a cold chisel or grind a punch to a flat edge. There's usually enough of a lip for you to get a start driving it out.
16 Mar 2012 18:15 #35665 by mlines
Replied by mlines on topic Re: king pin help
I would also suspect if you were to offer some beer tokens then a local BigJimny member might help out. If you were to offer more they might do it for you!
  • Ads1987
16 Mar 2012 18:41 #35666 by Ads1987
Replied by Ads1987 on topic Re: king pin help
I just did one side and it took 5 hours lol but it's the first time I've worked on the jimny since buying it two weeks ago. The guide on this site is brilliant! Make sure you have some degreaser handy to do the cv shaft etc. mine appears to have been bodged a bit by the last owner so had a few small probs but overall not too bad, the races came out with a decent chisel but the lower king pin was stuck pretty solid.
16 Mar 2012 19:44 #35674 by j999pre
Replied by j999pre on topic Re: king pin help
I don't think you'll have a problem. Best of luck and get stuck in.
Grey pick up Jimny
  • jonplace
17 Mar 2012 19:45 #35750 by jonplace
Replied by jonplace on topic Re: king pin help
a little tip,
I always have a bucket of hot water with a fair dose of fairy liquid in. king pins is a messy oily, gunky job and when starting to refit its handy to be able to dip hands and quickly clean off a bulk of the grime !!
Time to create page: 0.279 seconds
