Hub lockers
  • r7ynp1988
06 Mar 2012 21:34 #35072 by r7ynp1988
Hub lockers was created by r7ynp1988
Hi there
Does any one know if a set of manual hub lockers from a vitara would fit my 2001 jimny if i bought the adapter plates ?
Thanks.
06 Mar 2012 21:56 #35073 by Obarno
Replied by Obarno on topic Re: Hub lockers
Yes they should do, it's what I have on my auto Jimny. You will need the spacer ring and longer bolts from Martin and with that they will bolt straight on.
  • p1ngu32
07 Mar 2012 21:42 #35126 by p1ngu32
Replied by p1ngu32 on topic Re: Hub lockers
I have them on mine, they do fit with the spacer rings, but i still had to grind down the vaccum hub sealing ring on the hub nut to stop them fouling.
Time to create page: 0.077 seconds
