Front diff fit in rear????
  • Gdog14
28 Feb 2012 22:58 #34458 by Gdog14
Front diff fit in rear???? was created by Gdog14
hi guys
im planing on welding my rear diff for offroading but when im at home with it on the farm i want to have non welded one. I have a bent front axel with a good diff but i was wandering if it would go in my rear axel. so i could have it welded and the other one not and just swap them out when needed.
29 Feb 2012 10:14 #34482 by Obarno
No! They are quite different. The front diff is smaller and also a high pinion diff. You will have to find a rear diff, or fit a diff lock.
  • supergaz
29 Feb 2012 19:02 #34519 by supergaz
Replied by supergaz on topic Re: Front diff fit in rear????
Have you considered a lockright? Sounds like just what you need!
  • Gdog14
29 Feb 2012 19:40 #34524 by Gdog14
Replied by Gdog14 on topic Re: Front diff fit in rear????
supergaz wrote: Have you considered a lockright? Sounds like just what you need!
can you send me a link to one of them please?. Iv never heard of them.
  • dirtydogz
29 Feb 2012 19:51 - 29 Feb 2012 20:29 #34528 by dirtydogz
Replied by dirtydogz on topic Re: Front diff fit in rear????
Last edit: 29 Feb 2012 20:29 by dirtydogz.
  • supergaz
29 Feb 2012 19:52 #34529 by supergaz
Cant atm as I am on my naff android phone.
Martin sells them in the bigjimny shop, also jimnybits and bits4vits supply them.
I have just fitted mine and is a doddle, it is barely noticable on the road but off the road it keeps the rear axle locked.
Its a simple automatic diff that releases wind up in the halfshafts, similar to a clutch so it can slip. There are some fitting instructions on jimny.se, hopefully someone on a pc will link it for you.
Time to create page: 0.110 seconds
