On board air compressor
- Nelson83
28 Feb 2012 15:17 #34407
by Nelson83
On board air compressor was created by Nelson83
Thinking long term after a lift kit and either insa/ maxxis - im thinking about the inside mods of my truck. I've already van sided the back end and have a temporary full length cage in readiness to remove the rear seats and put in a false floor. Does any body have any suggestions as to what sort of on board compressor i can fit? I'd like one which can inflate tyres fairly fast and if needs be attach an air gun to blow tools clean etc when out in the field. The t-maxx ones from jimny bits look ok, but can anybody suggest anything better? One idea ive had is to mount a small garage one with a compressor and run it using an invertor
- adamjimny
28 Feb 2012 15:25 #34409
by adamjimny
Replied by adamjimny on topic Re: On board air compressor
I use a tmax one and its great but they work off and on off switch not a pressure switch and dont store pressure. I use the smaller one but i think the bigger 150l per minute one would do what you want to have a decent pressure to blow stuff down
Sent from my GT-I9100 using Tapatalk
- darthloachie
28 Feb 2012 15:45 #34412
by darthloachie
Replied by darthloachie on topic Re: On board air compressor
theres always an arb high output compressor - that has a pressure sensor and you can get an airline kit with it (cheaper to build your own airline with bits off ebay) - not cheap though
28 Feb 2012 17:08 #34419
Replied by mlines on topic Re: On board air compressor
If you fit a tank then that will improve the speed of tyre inflation. You can buy some smart purpose made tanks or pinch one from a scrap lorry.
Sent from my HP Touch pad running Android and Tapatalk
- ZookFastback
28 Feb 2012 17:38 #34422
by ZookFastback
Replied by ZookFastback on topic Re: On board air compressor
I bought this twin cylinder 150 litre/min, max 150 psi this year and it is very quick...
www.ebay.com.au/itm/12V-150L-MIN-PORTABL...4dc94#ht_4858wt_1132
Then I bought this tank to go in the car...
cgi.ebay.com.au/ws/eBayISAPI.dll?ViewIte...682020#ht_500wt_1057
It all works well and very fast GOTTA LOVE EBAY
- oxford_bloke
28 Feb 2012 18:33 #34431
by oxford_bloke
Replied by oxford_bloke on topic Re: On board air compressor
I know ARB make them. Also depending on winch make you can get an air spool for it instend of doing it all by hand, this is going to be my plan soon
Time to create page: 0.103 seconds
