jimny hubs
- Brooem
24 Feb 2012 21:06 #34153
by Brooem
jimny hubs was created by Brooem
is there a way to overide jimny hubs..? i have an event sunday and i cant get the spacer in time to fit my shj hubs..
quick fix needed please
- codpiece76
24 Feb 2012 21:38 #34156
by codpiece76
Replied by codpiece76 on topic Re: jimny hubs
if your replacing them get them in the locked position and weld them in place, easy fix
24 Feb 2012 22:01 #34157
by facade
Replied by facade on topic Re: jimny hubs
There is a thread on here somewhere, but just undo the bolts, pull them off, poke your finger inside, wiggle and pull and the inner splined bit will move outwards and lock the hub, then carefully replace, having disconnected the hoses so they don't come off again.
- Brooem
24 Feb 2012 22:02 #34158
by Brooem
Replied by Brooem on topic Re: jimny hubs
Being on a vacuum I'm thinking the locked position is in...
- Johnniehec
- Thank you received: 56
24 Feb 2012 22:44 #34159
by Johnniehec
Replied by Johnniehec on topic Re: jimny hubs
No it's out , depending how you look at it
Here's the linkhttp://www.bigjimny.com/index.php?option=com_content&view=article&id=208:51009-fixing-a-vacuum-hub-in-the-field&catid=42:drivechain&Itemid=37
I managed carefully with an imperial socket 5/16 I think, cos I don't have a 10mm torx.
Had my first hub malfunction at the weekend. Drivers side not locking, bit of moisture had got in, gave it a clean and re greased to fix.
John
John
- Brooem
25 Feb 2012 06:40 #34161
by Brooem
When I take the 6 bolts off my hub only the black cover comes off...
Time to create page: 0.089 seconds
