spring lift
  • rhondda jimny
17 Feb 2012 17:36 #33644 by rhondda jimny
spring lift was created by rhondda jimny
wanted some info on spring lift . got a pro comp 2inch shocks and spring lift for my jimny . just wanted to know would i need to remove the anti roll bar. and would i have to change anything or take anything off for this lift:blink:
  • myers647
17 Feb 2012 19:54 #33649 by myers647
Replied by myers647 on topic Re: spring lift
Hi mate I fitted a 2" lift to mine. You don't need to remove the anti roll bar. If you do it will give you more articulation, but it will handle really badly on the road,& you might need to replace it for your MOT. all I would advise you to do is get a set of brand new bolts for the shockers. It's an easy job to do.
If you do decide to take the ant roll bar off get some extended brake hoses.
Thanks
James
  • rhondda jimny
17 Feb 2012 20:51 #33652 by rhondda jimny
Replied by rhondda jimny on topic Re: spring lift
Ok thanks for that info . But I won't be removing the anti roll bar as I do a lot of road miles. So dnt want a poor handling jeep . What your thoughts on second hand springs and shocks ? They have covered roughly 3500 miles on road and 300 off road ? Or should I just get new ones
  • myers647
17 Feb 2012 21:06 #33653 by myers647
HI, if you do alot of road miles in the jimny then i would buy some castor correction bushes to center the steering wheel back to normal. I havnt bothered i have got used to it now, i do roughly 25 miles day. My lift kit was 2nd hand not many miles on it and it was fine , How much are you paying for it? I bought some shock re-location brackets to stop the rear sock hitting the rear springs when off roading as well.
Thanks
  • dirtydogz
17 Feb 2012 21:11 #33654 by dirtydogz
Replied by dirtydogz on topic Re: spring lift
If you buy a new 2" lift you will known it will all be ok, you will also need fit adjustable pan hard rods+ rear shock mounts+camber correction bushes.
  • rhondda jimny
17 Feb 2012 21:19 #33655 by rhondda jimny
How much are these bushes ? . Its going for £120 .
