Jimny Speakers
  • adamatdraycott
11 Feb 2012 18:25 #33286 by adamatdraycott
Jimny Speakers was created by adamatdraycott
Ever since i had my Jimny the drivers side speaker has been iffy... never really got round to having a look at it though.
Today i got a head torch on and looked through the trim, to see a big rip through the cone :blink:
So looking to replace them with something a little better.
Not bothered about masses of sound and would rather a
Does anyone know what adapters are needed? The PC2-802 looks right ish.
Would rather use an adapter rather than soldering spades on.
Cheers for any advice
11 Feb 2012 19:39 - 11 Feb 2012 19:40 #33296 by Halford
Replied by Halford on topic Re: Jimny Speakers
Hi Adam
can't advise on adapters, I'd just be using bullet connectors
all I'd say is that if I were doing mine again, I'd be looking to make the recesses bigger to take larger speakers, as even putting in better 4 inch than the standards, doesn't make much difference - I'd certainly consider doing some cutting work and putting in some a135 cms at least - or maybe even leaving the panels off with some surface mounted speakers down there.
have fun
Last edit: 11 Feb 2012 19:40 by Halford. Reason: 2nd bottle of champagne
  • ZookFastback
11 Feb 2012 19:53 #33297 by ZookFastback
Replied by ZookFastback on topic Re: Jimny Speakers
I went for the best quality 4" speakers I could find and then put 30mm ribbon tweeters up near my head to handle the higher notes that get muffled from being down in the footwell. It all works a treat :)
Ribbon tweeters with inbuilt crossover filter...
[IMG
Closeup of the 30mm tweeters...
[IMG
  • Mumbo Jimbo
11 Feb 2012 21:32 #33303 by Mumbo Jimbo
Replied by Mumbo Jimbo on topic Re: Jimny Speakers
That connector looks like it'll do the job, though some come with smaller spade connectors, I'll be making my own connectors as I don't want to modify the original wiring either.
I came across some old 3-way components that I had fitted to my old Orion way back so am looking at how I can get them into the Jimny at the moment. I have some 1" tweeters that I'll mount up high like ZukeFastback and some 4" mids that I'll put in the standard front location. just need to figure out where to put the cross-overs and the 6.5" mid/bass speakers, not sure if I'll get them in the standard rear speaker location.
  • VAXXi
12 Feb 2012 10:31 #33320 by VAXXi
Replied by VAXXi on topic Re: Jimny Speakers
The rears are also 10 centimeters in diameter; a 13 cm will barely fit with new holes for screws, but I'm doubtful about 16 cm ones.
  • adamatdraycott
13 Feb 2012 07:09 #33375 by adamatdraycott
Replied by adamatdraycott on topic Re: Jimny Speakers
I only ever listen to the radio on the way to work in the morning, so huge speakers aren't my thing ;)
I'll be fitting 100mm to match the standard... although will probably stick some better quality ones in. Halfruads have some Alpine ones for £25 'reduced' from £50
Is speaker depth a standard? The Sanyo ones are about 40mm deep, and there looks to be limited space.
Websites i've been looking on hardly list any specs, apart from the RMS and Max.
Time to create page: 0.115 seconds
