kill engine switch.
- Waite
11 Feb 2012 13:00 #33253
by Waite
kill engine switch. was created by Waite
Hi is it possible to put an underdash kill switch to a 02 jimny. And if so how do i do it. Reason is some toe rags broke in:( and tried to take j. I guess on a joyride with all the snow about. Any feed back wecome. (by the way j is fun in the snow)
- supergaz
11 Feb 2012 15:11 #33267
by supergaz
Replied by supergaz on topic Re: kill engine switch.
Your jimny has an immobiliser fitted as standard, the only way it can be started is with the key. It is not possible to hot wire them like you could do in seconds with old fords.
- viciouspenguin
11 Feb 2012 17:18 #33279
by viciouspenguin
Replied by viciouspenguin on topic Re: kill engine switch.
put a heavy duty relay inbetween the battery and main positive feed.
put a switch to the fuel pump.
put a switch to ignition
put 10,000v into the seat with a switch so u turn it off when you want to sit in it.
- stevedumptruck63
11 Feb 2012 19:12 #33291
by stevedumptruck63
Replied by stevedumptruck63 on topic Re: kill engine switch.
AK47 that would do the trick.:evil:
- ZookFastback
11 Feb 2012 20:01 #33298
by ZookFastback
Replied by ZookFastback on topic Re: kill engine switch.
- ZookFastback
11 Feb 2012 20:03 #33299
by ZookFastback
Memo to self... clean interior of Jimny
