kingpin bearings
  • rhondda jimny
  • Visitor
  • Visitor
12 Feb 2012 22:33 #33368 by rhondda jimny
Replied by rhondda jimny on topic Re: kingpin bearings
is this the parts i need for the king pin bearing change and inner and outer seals . on the photos of the inner seal you got on the king pin bearing change these small seals look different . the garage told me this is the kit yet only two bearing come with the kit ????. can you pleas help .
  • wanderinstar
  • Visitor
  • Visitor
13 Feb 2012 07:16 #33377 by wanderinstar
Replied by wanderinstar on topic Re: kingpin bearings
It looks like you have got a pair of swivel seals, one for each side and a pair of inner drive shaaft seals, one for each side. But only two kingpin bearings,enough to do one side only unless there are 2 bearings in each box. You need 4 bearing races and 4 outer tracks for each side
If you have a look at my photo above you will see what I look out of 1 side, bearing wise/
Where did you get them from and how much did you pay for them?
  • rhondda jimny
  • Visitor
  • Visitor
13 Feb 2012 17:23 #33415 by rhondda jimny
i got my jeep from a garage about 3months ago . the bearing was on they way out then leaking oil from the ball joint . so the jeep was under waranty for 3000miles since then only done 1000miles as i been waiting for the parts to come back . they keep saying the parts are in but cant find them . now they finally come back theres only 2 king pin bearings and the wrong seals for the inner drive shaft . driving me insane .
14 Feb 2012 13:52 - 14 Feb 2012 13:53 #33443 by ooky_123
Replied by ooky_123 on topic Re: kingpin bearings
You will need 2x kingpin bearings for each side (top and bottom)
The large dust seal you have isnt really needed (but good practice to replace).
www.bigjimny.com/store/index.php/service...g-kit-koyo-/p_6.html
If its leaking oil from the swivel, then thats a wheel bearing and oil seal that needs replacing ...
www.bigjimny.com/store/index.php/service...ng-kit-abk-/p_1.html
Former owner of Little "Ooky", who has now started a new life in Shetland
Last edit: 14 Feb 2012 13:53 by ooky_123.
  • wanderinstar
  • Visitor
  • Visitor
14 Feb 2012 16:53 #33450 by wanderinstar
Think you will find oil coming from swivel is due to kingpin oil seal failure/
www.bigjimny.com/images/documents/Changi...KingPin_Bearings.pdf
  • rhondda jimny
  • Visitor
  • Visitor
14 Feb 2012 17:12 #33453 by rhondda jimny
Thanks for the advice all. Finally got the job done in 5hours today . Can't change the diff oil now tho . Where do I get the tool for refill bolt and drain bolt ?
  • wanderinstar
  • Visitor
  • Visitor
14 Feb 2012 17:24 #33454 by wanderinstar
A 3/8" by 1/2" adapter.
14 Feb 2012 19:43 #33474 by mcjimny
Replied by mcjimny on topic Re: kingpin bearings
There are proper 10mm sockets available.
Time to create page: 0.166 seconds
