kingpin bearings
- rhondda jimny
- Visitor
05 Feb 2012 13:46 #32728
by rhondda jimny
kingpin bearings was created by rhondda jimny
hi there changing my kingpin bearings just wanted to know what grease i fill the ball joint back up with and how much ml do i put in there . i heard to put 300ml is this true ? on each side .
- supergaz
- Visitor
05 Feb 2012 13:55 #32731
by supergaz
Replied by supergaz on topic Re: kingpin bearings
This is the best grease to use
www.bigjimny.com/store/index.php/service...of-grease/p_130.html
05 Feb 2012 13:55 #32733
Replied by mlines on topic Re: kingpin bearings
The C.V joint itself should have around 100ml. I usually give the rest a generous dollop but you should not overfill as it will expand with the heat and squeeze out of the joint or wreck the joint through Hydraulic action, you need some air in there.
I can recommend this......
- rhondda jimny
- Visitor
05 Feb 2012 14:58 #32744
by rhondda jimny
Replied by rhondda jimny on topic Re: kingpin bearings
ok thanks for the info . will order this grease now . thanks again
- wanderinstar
- Visitor
05 Feb 2012 15:44 #32753
by wanderinstar
Replied by wanderinstar on topic Re: kingpin bearings
Make sure you get it well into the bearings. Otherwise this will happen
- wanderinstar
- Visitor
05 Feb 2012 15:46 - 05 Feb 2012 15:47 #32754
by wanderinstar
Last edit: 05 Feb 2012 15:47 by wanderinstar.
- rhondda jimny
- Visitor
07 Feb 2012 13:24 #32905
by rhondda jimny
when will have the grease and the sealant i orderd with you . ?? thanks
07 Feb 2012 13:33 #32908
At a guess tomorrow as they were posted first class, signed for.
- rhondda jimny
- Visitor
07 Feb 2012 13:37 #32909
by rhondda jimny
ok thanks you very much thats great
- rhondda jimny
- Visitor
11 Feb 2012 13:50 #33256
by rhondda jimny
only now the kingpin bearings come back and seals . only two boxes come back with bearing in . should there be 4 bearing all together ?
- rhondda jimny
- Visitor
11 Feb 2012 13:55 #33257
by rhondda jimny
this is what i got back .
- rhondda jimny
- Visitor
12 Feb 2012 22:28 #33367
by rhondda jimny
pics
Time to create page: 0.166 seconds
