wrong springs ??
- jo king
29 Jan 2012 14:28 #32105
by jo king
Replied by jo king on topic Re: wrong springs ??
TOP ADVICE dirtydogz
- reaper
30 Jan 2012 10:00 #32187
by reaper
Replied by reaper on topic Re: wrong springs ??
so what if i left the springa as they are and stuck a couple of 2" spacers in the front , would that cause any problems ?
- Johnniehec
- Thank you received: 56
30 Jan 2012 16:46 #32217
by Johnniehec
Replied by Johnniehec on topic Re: wrong springs ??
Bad luck reaper, you'd probably still not square it up with the spacers and you'd have at least 4inch lift at the back and about the same at the front so you'd need caster corrected radius arms or the steering'l be all over the place. I'd the same effect as you have now when I went to the tyre fitters with 30/950s on the back and standard 205s on the front!
john.
john.
- reaper
30 Jan 2012 21:18 #32258
by reaper
right o chief ....i will break out the big hammers :evil:
Johnniehec wrote: Bad luck reaper, you'd probably still not square it up with the spacers and you'd have at least 4inch lift at the back and about the same at the front so you'd need caster corrected radius arms or the steering'l be all over the place. I'd the same effect as you have now when I went to the tyre fitters with 30/950s on the back and standard 205s on the front!
john.
- Monkey
31 Jan 2012 08:58 #32272
by Monkey
Replied by Monkey on topic Re: wrong springs ??
You could lower the back by getting the front standard coils and putting them in the back. This give's about 65-75mm of lift...
Time to create page: 0.087 seconds
