Bonnet vent?
  • 247sniper
05 Jan 2012 08:12 #30044 by 247sniper
Bonnet vent? was created by 247sniper
Hi guys,
Where do you get the bonnets from with the vent in the middle of them? Is it a modification you add to the standard bonnet or is it a compete new bonnet?
Thanks guys,
Steve.
  • ZookFastback
05 Jan 2012 08:25 - 05 Jan 2012 08:26 #30045 by ZookFastback
Replied by ZookFastback on topic Re: Bonnet vent?
The bonnet vents are for the intercoolers on the turbo diesel Jimny. You can add shakers or intake vents or extraction vents to any bonnet,
www.jimny.se/Jimny%202005.jpg
www.kustombitz.com.au/UserFiles/2024-Fil...rCleaner_2_small.jpg
Last edit: 05 Jan 2012 08:26 by ZookFastback. Reason: fixing link
  • myers647
05 Jan 2012 11:54 #30049 by myers647
Replied by myers647 on topic Re: Bonnet vent?
I might get one off eBay and have a go at putting one on.they look good but are only on the turbo models. So it would only be for vanity to be honest.
James
  • ShuDuck
05 Jan 2012 17:55 #30067 by ShuDuck
Replied by ShuDuck on topic Re: Bonnet vent?
I like the look with the bonnet vent. Are the JP 660cc bonnet the same as the spanish diesel bonnet?
I think the bonnet and vent are one piece, an aftermarket vent would not look nearly as good IMO
  • r_ogilvy
05 Jan 2012 20:03 #30084 by r_ogilvy
Replied by r_ogilvy on topic Re: Bonnet vent?
problem is having an open bonnet vent leading to nothing could be the wrong idea if you do deep water alot. my jimnys always in water over the bonnet at the mo as the rivers and water holes are up.
as it will be coming in and pouring directly on to the engine. may not affect it but you never no.
looks good tho. :)
  • myers647
05 Jan 2012 20:12 #30086 by myers647
I was going to cut a hole and fit a scoop and then fiber glass and fill it so it looks like a one piece bonnet, but seal it in side so there is know where for the water to go straight through into the engine. I think it would look good but is it worth the hassel, this maybe a little project when i can drop on a bonnet cheap enough.
James
Time to create page: 0.095 seconds
