head lights taking on water
  • r_ogilvy
  • Visitor
  • Visitor
22 Dec 2011 08:19 - 22 Dec 2011 08:21 #28909 by r_ogilvy
head lights taking on water was created by r_ogilvy
Does anyone else get problems with the head lights steaming up and taking on a bit off water, iv been going through a lot of water recently and they keep condensating up, any one get this and what do you do to stop it?
Thanks
Last edit: 22 Dec 2011 08:21 by r_ogilvy.
  • wanderinstar
  • Visitor
  • Visitor
22 Dec 2011 08:42 #28910 by wanderinstar
Replied by wanderinstar on topic Re: head lights taking on water
Not experienced it myself. But where the bulbs fit into the unitI would give a liberal aplication of Vaseline around the inside ring of the large rubber ring that goes round the bulb, also round the outside of said ring. I presume there is a similar ring around the sidelight bulb. That should stop water getting into those 2 areas. The headlight may also need removing to dry it out.
Ian.
22 Dec 2011 11:32 #28918 by Johnniehec
wanderinstar wrote: Not experienced it myself. But where the bulbs fit into the unitI would give a liberal aplication of Vaseline around the inside ring of the large rubber ring that goes round the bulb, also round the outside of said ring. I presume there is a similar ring around the sidelight bulb. That should stop water getting into those 2 areas. The headlight may also need removing to dry it out.
Ian.
I'd definitely dry them out before you try to improve the seal otherwise you'll still get condensation.
  • darthloachie
  • Visitor
  • Visitor
22 Dec 2011 12:13 #28921 by darthloachie
Replied by darthloachie on topic Re: head lights taking on water
ours do
they dry out eventually :laugh:
22 Dec 2011 14:04 #28925 by ooky_123
Not really condensation, but back last year, I managed to fill ours up to the top with brown silty muddy water.
Took both units out, washed them out using hot water and detergent.. even bought a childs bottle brush to get most of the oily silt out.
Put them upside down next to a radiator for about 7 days, refitted with liberal amounts of vasaline around the bolb holders. Not had any issues since, but havnt really been swimming since the new radiator went in
Former owner of Little "Ooky", who has now started a new life in Shetland
  • r_ogilvy
  • Visitor
  • Visitor
22 Dec 2011 16:31 #28938 by r_ogilvy
Replied by r_ogilvy on topic Re: head lights taking on water
thats the problem i have dirty water in there about an inch of it, i will wash them out over the weekend.
and add some vasaline
thanks everyone
Time to create page: 0.138 seconds
