snorkel
  • wanderinstar
  • Visitor
  • Visitor
15 Dec 2011 20:08 #28306 by wanderinstar
Replied by wanderinstar on topic Re: snorkel
Not much difference between £25 and £169:ohmy:
  • russell
  • Visitor
  • Visitor
20 Dec 2011 14:52 #28700 by russell
Replied by russell on topic Re: snorkel
after alot of thinkng over diffrent ideas from silcone tube exsaust tube suction pipe ect i have fabricated a snorkel out of drain pipe i brought some 50mm tume and various fittings from b and q iv seen some retty nastey diy jobs but am very happy with how it turned out i have pics if any 1 is intrested
  • srcars
  • Visitor
  • Visitor
20 Dec 2011 16:57 #28714 by srcars
Replied by srcars on topic Re: snorkel
Yep post pics, Its always good to see other peoples modifications, I had a drainpipe snorkle on my last off roader and it held out to lots of abuse.
  • r_ogilvy
  • Visitor
  • Visitor
20 Dec 2011 17:15 #28716 by r_ogilvy
Replied by r_ogilvy on topic Re: snorkel
russell wrote: after alot of thinkng over diffrent ideas from silcone tube exsaust tube suction pipe ect i have fabricated a snorkel out of drain pipe i brought some 50mm tume and various fittings from b and q iv seen some retty nastey diy jobs but am very happy with how it turned out i have pics if any 1 is intrested
thats what i done, bought some 90 and 45 joints too. with 50mm and painted it black
Attachment IMG00427-20111220-1811.jpg not found
  • r_ogilvy
  • Visitor
  • Visitor
20 Dec 2011 17:16 #28717 by r_ogilvy
i would like to see a pic :cheer:
  • russell
  • Visitor
  • Visitor
20 Dec 2011 18:22 #28721 by russell
Attachment snorkel.JPG not found
Attachment snorkel2.JPG not found
Attachment snorkel3.JPG not found
Attachment snorkel4.JPG not found
right i started by removing the air cleaner and inner wing i removed the originaol air intake i saved the rubber 90 dergree end witch usally points to the head lamp area you can see in the pics that a 50mm straight b and q drain pipe fitting fits into the air into rubber really snug and with a libral coating of silicone its very watter tight, i then fitted the rubber 90 degree from the original intake pipe to the end of the newly fitted stump on the air cleaner i then routed the drain pipe in side the wing 3 no degree fittings and a 145 to bring the tube out of the wing and up the a post i made a small bracket with i rivited inside the a post and onto the tube i cut the original air intake so i had a nice 90 and ritted a robin relaiant heater filter to the inside to give me a safari snorkel stlye grill to stop leaves or sparows ending up in m y air cleaner i then siliconed all the joints and tested with easy start i used proper gutter glue to glue the pipe fittings together so i should be very water tight fingers crossed
Time to create page: 0.143 seconds
