Death Wobble cured
- jo king
10 Dec 2011 15:48 #27778
by jo king
Death Wobble cured was created by jo king
Took brakes apart today as the car was pulling to the right. The calipers were fine as the pads and the discs. But on closer inspection I realised that the pads were stuck fast
after tapping them out I took the little stainless retainers out and cleaned them up with a knife and did the sames to the pads were they fit in at each end. And cleaned all the rust where the retainer clips fit which enabled me to fit the pads back in with ease. The pads now move with ease and then I noticed that the disc was slightly warped but only slightly. Did the same the other side. The result si zero wobble :woohoo: . which tels me that this could be the main factor to the elusive death wobble problem.. The king pins were done about 5 weeks ago so I knew it could not be that. Had this problem before on a black soft top and I pushed the calipers out on both side and did not touch the brake pedal while driving and had no problems until I had to brake and thats when the wobble came back. My truck is lush to drive now
- Foxtrot
11 Dec 2011 16:44 #27885
by Foxtrot
Replied by Foxtrot on topic Re: Death Wobble cured
Hi Jo King, I had something similar with mine, slowing down at high speed (50mph >) resulted in the steering wheel wobbling like mad. On inspection the disks were warped and scored, like yourself after changing the disks and brake pads it was ok, thanks for sharing as it confirms the same problem
- reaper
11 Dec 2011 16:50 #27886
by reaper
Replied by reaper on topic Re: Death Wobble cured
any distortion in wheels brake disks etc in fact any part that has rotating mass will cause an unbalance
many jimnys suffered the "death wobble" due to shim wear and the bearings ,this is a problem well known to suzuki but they seem to not want to do a recall or even admit its a problem
i believe they revised it after 2004
12 Dec 2011 12:58 #27979
by saxj
Replied by saxj on topic Re: Death Wobble cured
Nope! I have a 2008, still happens.
- jo king
12 Dec 2011 15:53 #27993
by jo king
Replied by jo king on topic Re: Death Wobble cured
Have you checked the pads to see if they can slide out and back in!!
- Cash
17 Dec 2011 17:15 #28466
by Cash
Replied by Cash on topic Re: Death Wobble cured
I reckon the death wobble is purely a frequency issue. My 07 has just about had it in all variations. I've fitted and pre-loaded new king pin bearings, fitted new swivel seals (as Suzuki recommend in the w.s manual to damp it out), they all worked to a point. I had the front wheels balanced mid rim not the edges (now that did work). Last year I fitted a new pair of tyres and tried the 5 stud flange mount balancing method and it came back but no to badly and at that point I gave up deciding to live with it.
Two days ago I had a puncture in a rear tyre. After refitting the repaired and balanced wheel the wobble came back big style. It was then I remembered my old mate's then brand new early front wheel drive Escort had to have the rear wheels carefully balanced or the steering would vibrate like hell. I had both rear wheels carefully rebalanced and bingo no wobble. Is that how they fixed it under warranty without any signs of actually doing anything??
My mate's 04 without anti-roll bars model has never had the wobble and it's covered 120,000 miles.
I've got a LR steering damper and I've threatened the Jimny if it doesn't behave I'll fit it this summer.
Cash
Cash
