Greetings and some advice.
- SOTA
- Visitor
06 Dec 2011 22:32 #27430
by SOTA
Greetings and some advice. was created by SOTA
Hi Folks, n00b here just got my jimny a few days ago. Not even had time for pictures yet!
It's a metallic blue x reg manual hard top, has a few miles, but with some work it should do all that I need of it.
Where can I get cheap AT tyres?
My jimny will be used mostly around quarry and farm tracks. I haven't decided whether to lift it yet.
The kid in me wants massive tyres and stratospheric lift, the middle aged scrooge in me wants to keep it cheap. :lol:
07 Dec 2011 06:49 #27435
by kirkynut
Replied by kirkynut on topic Re: Greetings and some advice.
Welcome along!
For what you want it for I would go for a 2" lift and slightly bigger tyres.
Have a look at Kumho KL71's as a quiet hard wearing mud terrain that you may be happier with than a all terrain.
Ruts will be where you get stuck on farm tracks.
- darthloachie
- Visitor
07 Dec 2011 07:48 - 07 Dec 2011 07:48 #27444
by darthloachie
Replied by darthloachie on topic Re: Greetings and some advice.
Hello and welcome
glad to see you bought the best colour :laugh:
I agree with kirknut - you can get some good MTs which are also good on the road for less than the big name ATs
As well as the Kuhmo also look at maxxis trepadors at about £80 as they get good reviews
Last edit: 07 Dec 2011 07:48 by darthloachie.
07 Dec 2011 07:55 - 07 Dec 2011 07:57 #27445
by dirtydogz
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Replied by dirtydogz on topic Re: Greetings and some advice.
Hi and welcome.
Try here
www.4x4tyres.com/
www.camskill.co.uk/
www.tyresdirectuk.co.uk/xcart/category_4x4.php
Try here
www.4x4tyres.com/
www.camskill.co.uk/
2002 JLX Soft Top
Last edit: 07 Dec 2011 07:57 by dirtydogz.
- SOTA
- Visitor
07 Dec 2011 18:37 #27487
by SOTA
Replied by SOTA on topic Re: Greetings and some advice.
Thank you, nice to be here.
I see on bits4vits they have a 1.5" lift/spacer kit. Is that easy to do for someone who doesn't have a garage to work in?
Do I need to compress the springs?
I was also thinking of some wheel arch trimming to accommodate the bigger tyres. My jimny is currently wearing bridgestone duellers, 2 of which need replacing soon.
07 Dec 2011 20:29 - 07 Dec 2011 20:34 #27498
by dirtydogz
2002 JLX Soft Top
lts the same as doing a spring lift.
www.bits4vits.co.uk/store/vitara-/-x90/s...acers-4-/prod_3.html
www.bits4vits.co.uk/springspacerinstructions.pdf
Fitting a 2"or 3" lift.
If you got a set of longer brake hoses fit them first.
Next
(WD40)all the nuts and bolts on the shocks for about 2 days before starting.
Start with the back axle,undo the wheel nuts a little,then jack up on the chassis on both sides and lower on to axle stands as near to the radius arms as possible , so the tyres are about 2" off the ground,now remove the wheels.
Next place the trolley jack in the middle of the axle, jack it up so you can remove the nuts+bolts from the shocks.
Next lower axle down and remove the old springs+shocks, you might need a mate to help you fit the new springs+shocks back on, or a length of wood to lever the axle down to get the new spring on.
Now do the the front the same way as the back.
When your finished CHECK all the nuts +bolts+ wheel nuts are tight.
www.bigjimny.com/index.php?option=com_ku...8&id=10688&Itemid=75
Next
2002 JLX Soft Top
Last edit: 07 Dec 2011 20:34 by dirtydogz.
Time to create page: 0.158 seconds
