Lift kit
- Member
22 Nov 2011 16:20 #26302
by Member
Lift kit was created by Member
how long does it take to fit a 3inch pro comp lift kit?
springs
shocks
brack hoses
castor correctors bushes
panhard rods?
just a rought guess?
would i need anything else not getting new radius arms atm do to budget
springs
shocks
brack hoses
panhard rods?
- supergaz
22 Nov 2011 16:42 #26308
by supergaz
Replied by supergaz on topic Re: Lift kit
Id guess no more than 3 hours if the castor correction bushes were already pressed into the arms. Getting the new polybushes in is easy, getting the old ones out without a press is a pain but possible. Id also consider rear shock brackets if not castor correcting the rear, or the bushes will get mashed.
22 Nov 2011 16:58 - 22 Nov 2011 16:59 #26310
Replied by mlines on topic Re: Lift kit
Cutting off the corroded shock bolts.....
Cutting off the corroded radius arm bolts....
Cutting off the corroded panhard rod bolts....
Shearing off the brake connectors, making up new connectors and pipes
Trying to press out radius arm bushes...
Guess what I am doing!!!
Last edit: 22 Nov 2011 16:59 by mlines.
- Dutchjimny
22 Nov 2011 17:00 #26311
by Dutchjimny
Replied by Dutchjimny on topic Re: Lift kit
I guess the longest bit is taking the radius arms off and get them repressed at a garage
- Dutchjimny
22 Nov 2011 17:02 #26312
by Dutchjimny
@ martin : little offtopic but what sort of replacment bolts do you use? 8.8?
22 Nov 2011 17:14 #26313
Yes 8.8
Available in BigJimny store!
Time to create page: 0.140 seconds
