jimny crawler gear
- bari
01 Nov 2011 19:18 #24975
by bari
jimny crawler gear was created by bari
hi everybody has anybody any experience of the crawler gear thats for sale on jimnybits.
www.jimnybits.co.uk/shop/jimny/jimny-low...earset/prod_466.html
wich will be the lower gearing this or the rocklobster sj box.And wich would be robust.
- TomDK
01 Nov 2011 19:24 #24976
by TomDK
Replied by TomDK on topic Re: jimny crawler gear
The rocklobster is much lower. This gearing from jimnybits is hardly what you'd call a crawler gear
- mark1971
02 Nov 2011 07:05 #25006
by mark1971
Replied by mark1971 on topic Re: jimny crawler gear
Can you fit a rocklobster box to an electronic selector jimny? Or would I need to have the second shifter through the floor?
Mark
Mark
02 Nov 2011 07:09 #25007
Replied by mlines on topic Re: jimny crawler gear
You would need to have the second shifter through the floor, but every electronic Jimny I have seen so far has a plate screwed down over the hole so you can simply remove the plate.
You also have to fool the electronics if you dont want the warning lights on the dashboard to come on, there are a couple of wires you need to cross-connect.
- mark1971
02 Nov 2011 09:05 #25011
by mark1971
Thanks for the swift response Martin. It's a question I've been mulling over for a while as I do find the normal low box is to high when I'm going down steep stuff. Time to start saving the pennies up.
Mark
Mark
- bari
03 Nov 2011 11:06 - 03 Nov 2011 11:11 #25054
by bari
Replied by bari on topic Re: jimny crawler gear
hi, i dont know much about how much 2.65:1 in low range would infect my jeep but i want to lower the gearing so that when im in 1 gear in low range now, it would be the same as in 3rd with the lower gearing
what gear ratio would i need?
thanks bari
thanks bari
Last edit: 03 Nov 2011 11:11 by bari.
Time to create page: 0.099 seconds
