Any one selling T-Max EW-6500 12V 6500 lbs Winch
  • mark1971
  • Visitor
  • Visitor
31 Oct 2011 12:03 #24900 by mark1971
How about a champion 8000 winch? Got mine on eBay for £230 and it was delivered the next day. It fits perfectly between the chassis rails, I just lengthened the rails and welded a winch plate in.
  • r7ynp1988
  • Visitor
  • Visitor
31 Oct 2011 21:53 #24944 by r7ynp1988
Hi Mark
Was that brand new ?, Do you have any picture's with the front bumper off to see where to weld it in ?. Also where did you get the winch plate from.
Ryan.
  • mark1971
  • Visitor
  • Visitor
01 Nov 2011 06:43 - 01 Nov 2011 06:49 #24948 by mark1971
The seller is autoliftukltd..... I paid £260 max for the winch and the correct winch plate and that included next day delivery. As for the installation it was pretty much identical to the pictures on here under the how to fit a winch post. Basically I cut the crush cans off the front of the chassis, inserted box section of a slightly smaller diameter then welded the winch tray in between. The tray needed trimming down a bit to fit in snugly. After that I just trimmed the bumper down so I just fitted over the winch, all I lost was the mesh over the big hole in the bumper and the lower part of the painted bit where the number plate was screwed into. Then I trimmed the lower bumper section and popped that back too, job done. Although I dabble with a welder I got a mate to do mine as his welder was a big workshop one and much better / capable of producing quality welding.
Last edit: 01 Nov 2011 06:49 by mark1971.
  • mark1971
  • Visitor
  • Visitor
01 Nov 2011 06:48 - 01 Nov 2011 06:49 #24949 by mark1971
And my winch came with a cool remote control kit so I can even winch remotely from outside the vehicle if the need ever arose and also means no having to plug the wired controller into the solenoid box every time I want to winch. Thought about installing the wired controller In permanently and fitting the switch on the dash to make life easy.
  • r7ynp1988
  • Visitor
  • Visitor
01 Nov 2011 19:53 #24984 by r7ynp1988
Hi m8
Think I am going to go with buying a new one so I know it is going to be reliable, Think I am going to go for the champion 8000.
Cheers Kirkynut
  • r7ynp1988
  • Visitor
  • Visitor
01 Nov 2011 20:03 #24987 by r7ynp1988
Hi Mark
Cheers I will go on and have a look at them and get one ordered up, Does the person selling the winch supply the correct winch plate aswel ?. Mark what model is your winch there is about four champion 8000 to chose from, I have a friend with a decent welder I will get him to do the welding and al do the cutting lol. Also do you have a pic of the finished result ?
Cheers
Ryan.
Time to create page: 0.169 seconds
