Unplanned mods...
  • SPC5838
15 years 1 month ago - 15 years 1 month ago #24070 by SPC5838
Unplanned mods... was created by SPC5838
The local wildlife decided to help mod the jimny this morning. I'm not that chuffed with their effforts though :pinch:
Attachment 2.JPG not found
Attachment 1.JPG not found
This is what happens when a buzzard decides to fly low over the dual carriage way and meets a Jimny doing 70... It broke straight through, nowt like glass shrapnel firing around inside the car to wake you up in the morning :ohmy: Especially with an arse in a BMW hard up your back bumper cause being passed by a Jimny dented his ego, meaning the instinct to brake when your being peppered with glass splinters would have ended in much more damage :woohoo:
Now fixed, but has anyone else had a new screen in and how well was it fitted ? Autogl*ss changed it and they've used a universal seal - The screen now moves when you push it ( in and out ) by a good couple of mil and the scuttle panel trim has a gap of 1 - 2 mm from one side to the other at the bottom of the screen as the new seal doesn't let it fit correctly. We won't mention the left hand interior A post trim being off where it fits to the dash, the paint damage, scratches from screw drivers being used as leavers, phone charger cable that came out through the right hand B post being left hanging at the side of the dash etc. just now... :angry:
Last edit: 15 years 1 month ago by SPC5838.
  • Az1987
15 years 1 month ago #24072 by Az1987
Replied by Az1987 on topic Re: Unplanned mods...
Your not the first person to have a problem with auto glass doing a poor repaire phone up and complain if it is that bad they will come out and repaire it again plus all damage done
  • zaine
15 years 4 weeks ago #24089 by zaine
Replied by zaine on topic Re: Unplanned mods...
id definately complain, scratches to the paint and not correct fitment!!
  • darthloachie
15 years 4 weeks ago #24092 by darthloachie
Replied by darthloachie on topic Re: Unplanned mods...
also if it is bonded in then it will take 6-8 hours for the sealer to set - before that the screen will move if you push it and may also cause it not to bond properly and leak - they usually tell you not to drive it until several hours have passed
however I agree they should not have scratched or damaged it.
lucky its not a bmw mini as you would have had to have 2 new windscreen trims at £50+ each as they usually break when the screen is being removed
  • adamatdraycott
15 years 4 weeks ago #24096 by adamatdraycott
Replied by adamatdraycott on topic Re: Unplanned mods...
Had a screen re-placed on an S-Max, after the heating elements decided not to work (warrenty claim ;) )
AutoGlass fitted it using sticky black sealant... which when the screen was pushed onto seeped out and easily visible from inside the car. They then broke the corner off the screen and didn't mention it. They were called back and replaced it again... again the black sealant was visible but lived with it.
They also used their resin on a chip on my Fiesta, fine from outside, but rubbish from in. But the chip never cracked so no biggy.
  • SPC5838
15 years 4 weeks ago #24146 by SPC5838
Replied by SPC5838 on topic Re: Unplanned mods...
Had them come back today - the screens coming out and being refitted. When it was checked again it still flexed at the top, apparently on the seal. Apparently there's two different seals ( different maker presumably ) one's good and to quote the fitter, the other one's "s**t". No points for guessing which one I had fitted to mine....
Hopefully it'll be OK when it's refitted. In fairness to them, there was no argument about getting it done but if anyone else gets a screen in would seem it's worth having a good look at the rubber that it's fitted with in case it's the crap one.
Time to create page: 0.114 seconds
