How much lift before you need Castor Correction??
- blitzn
- Visitor
07 Oct 2011 00:46 #23184
by blitzn
How much lift before you need Castor Correction?? was created by blitzn
Hey All,
Looking at putting in a little lift kit in the Jimny. Question is how much can i raise it without having to install castor correction bushes?
Im only looking at 20-25mm lift at this stage. Has anyone got away with this kind of lift and it still driving nice at motorway speeds?
Cheers
Als
Cheers
Als
07 Oct 2011 05:43 #23188
Replied by mlines on topic Re: How much lift before you need Castor Correction??
The general rule of thumb is that castor correction is not needed for lifts up to 2 inches (50mm)
- renard38
- Visitor
07 Oct 2011 17:04 #23227
by renard38
Replied by renard38 on topic Re: How much lift before you need Castor Correction??
i've drived a long time without castor correction with +3", and no problem. But now with casor correction, driving is more pleasant, the direction is more stable
07 Oct 2011 17:26 - 07 Oct 2011 17:29 #23230
by dirtydogz
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Replied by dirtydogz on topic Re: How much lift before you need Castor Correction??
I have a 1.5" or 38.1mm lift on my jimny with no castor correction bushes and i've had no problems.
2002 JLX Soft Top
Last edit: 07 Oct 2011 17:29 by dirtydogz.
07 Oct 2011 18:08 #23234
by kirkynut
Replied by kirkynut on topic Re: How much lift before you need Castor Correction??
As Martin says, the rule of thumb is up to 2" does not need castor correction but as Renard38 says, I have had a 3" lift for a while with no real issues!
It may pay to fit the lift kit and see what you think. If you don't like the light steering and it doesn't self centre enough for you, do something about it. If you can live with it, don't!
Time to create page: 0.137 seconds
