CV Joints on Ebay
- Baz2236
16 Feb 2010 12:58 #2304
by Baz2236
CV Joints on Ebay was created by Baz2236
Hi Guys just to let you know when / if you smash a CV joint don't bother buying one from these guys on Ebay www.ebay.com/itm/350310570403 Its the wrong one, I have told them but they says its because I have a different one in my Jimny.
I thought I was going to get a bargain for only £22 quid I should of known that Suzuki bits are more expensive then that.
I should hopefully get a refund from them and have just order 1 froms camskill so hopefully be back on the road by the weekend.
Baz
Baz
16 Feb 2010 13:21 #2305
Replied by mlines on topic Re:CV Joints on Ebay
I think there is a general rule with Suzukis, if the part is cheap then its the wrong one! A couple of us have been down that path with the wheel bearings!
There is some hope on the horizon, Rob from this forum seems to have found a source of cheap Tie-Rod ends. The part numbers do seem to tie (no pun intended) up and once he confirms it actually fits, I will post further info. Up to now I have really struggled to find tie-rod ends at below £45 each but it now looks as if the manufacturer has not listed them as being suitable for Jimnys when they are. If you look up "Jimny" on the manufacturers website it fails to list anything. When you look up the part number (ie a reverse lookup) it comes up with....Jimny! So you have to know the part number before you can look up the part number - crazy!
Currently seem to be about £18+VAT
- Baz2236
16 Feb 2010 13:32 #2307
by Baz2236
Replied by Baz2236 on topic Re:CV Joints on Ebay
It seems Camskill are having trouble geting CV Joints as well
Maybe I won't be back on the road this weekend.
Hi,
At the moment neither us or ADL blueprint have stock of this cv joint and furthermore ADL cant give us a due date as to when they are getting some more. Would you like us to try and find a different supplier for this part? Please advise
Camskill
16 Feb 2010 13:35 #2308
I have found these guys -
www.reco-prop.com/
really good for this in the past, but NOT cheap. However if you are desperate to get on the road......
16 Feb 2010 13:36 #2309
and if you speak to them please enquire about hardened ones, I would love to find a source of stronger ones!
- Baz2236
16 Feb 2010 13:47 #2310
by Baz2236
Camskill have found me a ADL blueprint one for only £7 more :woohoo: :laugh:
:woohoo:
Time to create page: 0.096 seconds
