losing power
  • sallystrawberry
25 Sep 2011 18:50 #22525 by sallystrawberry
losing power was created by sallystrawberry
My Jimnys Engine light is flashing on and off, Engine losing power
25 Sep 2011 19:44 #22535 by facade
Replied by facade on topic Re: losing power
Welcome to the forum.
I'm afraid we need a bit more to go on.
The engine light tells you something is wrong, and the engine goes into a reduced power limp home mode.
When does the light come on?
If you want to know what is wrong, you will need to find someone who can plug into the diagnostic socket to read the fault codes.
I can guess for you and suggest that the crankshaft sensor is failing: this will put the light on after a few minutes driving on a motorway, longer in cold weather, and cause a missfire. Switching off and waiting a few minutes will put it back out and you can carry on for a while. A new one is required.
  • sallystrawberry
25 Sep 2011 20:29 #22541 by sallystrawberry
Replied by sallystrawberry on topic Re: losing power
HI forgot to say mines a1999 model. The engine light came on about a minute after i started driving it. then started juddering all the way home. When i start engine, rev it a bit, light flashes and engine misses.
Time to create page: 0.086 seconds
