How many revs @ 100km/h? G Series Gearbox Oil Leak
  • blitzn
  • Visitor
  • Visitor
21 Sep 2011 18:29 - 21 Sep 2011 18:34 #22297 by blitzn
Hey All,
Just a quick couple of questions,
1st how many revs are most of you doing when sitting at 100km/h? In mine im still on just over 3000 revs and doing maybe 90km/h - 2000 model jimny with 215 tyres. Just wondering if this is kinda normal. There was a reciept with the vechical when i bought it for new diif!? i have yet to check it is the correct ratio but it seems that i am doing around 3500-3600 revs at 100km/h just seems a little high especially with 215 tyres. and yes my speedo is out a little i know with bigger tyres but am taking that into consideration.
2nd Have this damn oil leak from the back of the gearbox! G series one. I have replaced the Jack shaft output seal twice, once with a cheap one, still leaked oil and 2nd time with a geniune Suzuki one. Still got a leak. The shaft is fine smooth and tight fit with the seal. I checked last nigth the breather and it seems to be not blocked? I cant get the output shaft to move eg no play in the gearbox bearings.
Is there any where else that may be causing an oil leak on these gearboxes that people are aware of??? Just one of those anoying things grrr. It looks to be coming from the output seal then splashed all over the tunnel from the shaft turning. Im at the stage where i am going to have to pull the box out to look into it to see what is going on :(
Cheers
Alan
Last edit: 21 Sep 2011 18:34 by blitzn.
  • Sandez
  • Visitor
  • Visitor
21 Sep 2011 19:38 #22305 by Sandez
When I cruised at 110km/h on stock tyres I was sitting around 4500-4600rpm. With 215/70/15 it now sits around 4200rpm. Mine is the M13A, so gearbox could be slightly different?
  • ZookFastback
  • Visitor
  • Visitor
22 Sep 2011 09:56 #22331 by ZookFastback
My Santana Suzuki ragtop 2000 Jimny sits on 4100 rpm at 100 kph. Tyres are 215/65 15's M&S
  • blitzn
  • Visitor
  • Visitor
22 Sep 2011 18:14 #22357 by blitzn
Ok cool!
Doing 4000 revs in mine im doing 100km/h and at 3000 revs it doing around 75km/h Guess they just rev that high factory.
Where is the 6th gear?
Cheers
  • VAXXi
  • Visitor
  • Visitor
22 Sep 2011 18:25 - 22 Sep 2011 18:28 #22358 by VAXXi
You should state the engine and modifications, to be correct. Mine does 90 km/h at exactly 3000 rpm with the VVT 1.3 engine, with the modifications listed in my signature.
For the seal, I remember quite a lengthy discussion on the german Jimny forum where a member had the same problem. Through what I could understand with Google Translate, he seemed to mention it's related to the install; after putting the seal in, it had to be turned somehow for a lip to catch and stop the leaks. I've also seen a bit of oil splashed in that area and will take care of it soon.
Last edit: 22 Sep 2011 18:28 by VAXXi.
  • Back in Black
  • Visitor
  • Visitor
23 Sep 2011 10:02 #22381 by Back in Black
Replied by Back in Black on topic Re: How many revs @ 100km/h? G Series Gearbox Oil Leak
Hi,
my 1999 hardtop @ 100kph is sitting 3500 revs, and shaking sooooo much the stereo comes out the dash :sick: ! I've got 235/75 MT's fitted (30" tall)??
26 Sep 2011 09:45 - 26 Sep 2011 09:46 #22558 by Obarno
Mine is a 2007 VVT and suffers the problems of putting a rocklobster transfer box in it. Even though I have changed the diffs from 4.3 to 3.9, and running 30" tyres its still very low geared. 100kph is achieved at 4500 rpm. Not really good for the car but the upside is its great off road!
An ideal mod would be an earlier gearbox, but even that's not straight forward as they are a completely different box.
Can't remeber what the auto does at 100 kph but its a lot less.
Last edit: 26 Sep 2011 09:46 by Obarno.
  • renard38
  • Visitor
  • Visitor
26 Sep 2011 16:42 #22594 by renard38
235-75-15, transfert box 4.16, 80 km/h at 3000rpm and 100km/h at 4000 rpm ;)
  • renard38
  • Visitor
  • Visitor
26 Sep 2011 16:48 #22596 by renard38
  • lukeyblunt
  • Visitor
  • Visitor
26 Sep 2011 17:38 #22609 by lukeyblunt
I'm on stock everything, doing just over 3500revs at 100kph.
  • Dorfl
  • Visitor
  • Visitor
30 Sep 2011 08:03 #22801 by Dorfl
2008 VVT 4400 rpm @ 90 kph and ~4600 rpm @ 100 kph
