Dilemma
  • adam
15 years 2 months ago #21663 by adam
Dilemma was created by adam
Hi all, I have a little dilemma and thought you might be able to help. I just bought the 1.5” spring spacer kit from Bits4Vits. I have spent most the day getting it on mainly as the bolts were so stuck. Anyway for those of you that don’t know what comes in the kit, it comes with 1.5” spacers, rear shock re locators and front shock extensions. All went on fine with a little help with my friend Mr hammer! Apart from I could not for the life of me get my front shocks un done at the top so I haven’t managed to get the extensions in. My dilemma is do I buy new shocks and just cut mine off? I have seen from Jimny Bits I can get Pro comp shocks in lengths of standard/ 1” or 2”. What should I buy? Will the extensions fit the pro comps on the standard or do I buy the 1” or 2”?
Any ideas???
Thanks
Adam
  • supergaz
15 years 2 months ago #21664 by supergaz
Replied by supergaz on topic Re: Dilemma
I'd buy extended shocks, this will give added articulation if the ARB is removed.
  • mcjimny
15 years 2 months ago #21674 by mcjimny
Replied by mcjimny on topic Re: Dilemma
When you say you can't get them undone do you mean that the shock keeps rotating with the nut?
I would use the extensions personally as dave has tailored them to match the spacers.
  • vitara_mad
15 years 2 months ago #21683 by vitara_mad
Replied by vitara_mad on topic Re: Dilemma
the top of the front shocks are a pain in the butt but if you use a good ring spanner & a good quality pair of vise grips to hold the top they should come off but if all fails you will just have to cut them off & get some replacements
i have some standard jimny shocks available if you need some
i think you will find that the shock extenions you have for the standard shocks will not fit on pro comps if you wanted to as they use a totaly differant thread
  • adam
15 years 2 months ago #21705 by adam
Replied by adam on topic Re: Dilemma
Yeah, my friend and I spent ages. there was no getting them off.
He said we would snap them if we used a bigger bar! :sick:
We also snaped one other bolt which luckerly he had a spare rattling around in is bobtail!
Can I use the 2" procomp or will they be too long?
I had to pick the mrs up last night, 15 miles on the motorway and 15 miles on A roads in High winds and seemed ok but assume its still best to add the extra length to the front shock especially for off roading!
Thanks people for your inputs so far and vitara_mad Ill let you know if I need thoughs shocks thanks!
In the mean time, it wont effect my Jimny too much will it? I like the new height and almost feels softer than before.
Thanks
Adam
  • vitara_mad
15 years 2 months ago #21710 by vitara_mad
it will be perfectly fine to drive with the sping spacers & standard shocks
Time to create page: 0.096 seconds
