Brrrrt
  • Northern-Wanderer
15 years 2 months ago #21566 by Northern-Wanderer
Brrrrt was created by Northern-Wanderer
Hi All,
I have a 2010 jimny with 10,000 mile & was wondering if the Transfer box drivechain is driving when in 2wd.I ask as i sometimes get the "Brrrrt noise when pulling away and all forums suggest the chain is slipping.The main stealer says it is nothing to worry about,but i cant trust them.
Thanks
15 years 2 months ago #21570 by Halford
Replied by Halford on topic Re: Brrrrt
Hi Wanderer, welcome to BJ from South Shields
- does it only happen after you've just started the engine and drive off - or every time you pull away whilst out and about ?
Every time I pull away I get a hehehe noise, cos I luv my Jimny.
Don't forget some pics of a nice new JImny :lol:
The following user(s) said Thank You: Northern-Wanderer
15 years 2 months ago #21573 by facade
Replied by facade on topic Re: Brrrrt
If the chain is jumping the sprockets, the BRRRTTT noise is very loud, pedestrians would be looking at you.
If it is very loud the dealer should explain what nothing is, or at least demonstrate that a new one does it too.
FWIW, I doub't the chain has gone after only 10,000 miles, they are good for 150,000 if the oil is kept clean.
15 years 2 months ago - 15 years 2 months ago #21589 by Halford
Wanderer has advised the problem first arose, occasionally giving the BRTTT when pulling away in 2wd on hills, however, now it "sometimes" does it even on the flat,
only happens in 1st gear,
not very loud but all inside hear it
only happens for a second,maybe less.
Any ideas :unsure:
Last edit: 15 years 2 months ago by Halford. Reason: more info from Wanderer
15 years 2 months ago #21613 by mlines
Replied by mlines on topic Re: Brrrrt
I have had two chains slip over time (on modified transfer boxes).
The BRRT noise is loud and can be felt through the transfer lever.
It starts off only happening in 1st on a slope, then 1st and 2nd, then 1st and 2nd on the level.
The more revs, the more it happens.
15 years 2 months ago #21632 by facade
Is it more of a BRRRRRRRRRR as the whole back of the car vibrates? This happens below 1500rpm on most jimnys. Feels like the back axle is falling off.
I would take the thing back and insist that someone comes out in the car to hear it.
Could be something loose, like a heatshield on the exhaust.
Time to create page: 0.091 seconds
