Front Bash Plates
- doncarlyon
15 years 2 months ago #21181
by doncarlyon
Front Bash Plates was created by doncarlyon
Who has one?
Where from?
How have you mounted it?
Where from?
- Keefe
15 years 2 months ago #21188
by Keefe
Replied by Keefe on topic Re: Front Bash Plates
1/ I haven't.
2/ I don't know
3/ Let me know as well if you do find out.
Yes, I would be interested the answer to the above as well.
Steel or 5-6mm ally?
K
2/ I don't know
K
- doncarlyon
15 years 2 months ago #21198
by doncarlyon
Replied by doncarlyon on topic Re: Front Bash Plates
I mainly want one to tidy up the front end where you can see the ends of the chassis legs. But suppose it could give some more protection aswell.
Steel plate would do the trick, with some holes in and paint it black to match the rest of the car
- SPC5838
15 years 2 months ago - 15 years 2 months ago #21358
by SPC5838
Replied by SPC5838 on topic Re: Front Bash Plates
1) I do
2) B&Q, at least the galvanised sheet it's made of did.
3) On the mounts under the front end for a bash plate, that presumably Suzuki maybe made at some point but doesn't seem to exist . Or decided not to fit, but left the mounts in place :huh:
I had much the same idea, but wasn't really too keen on the first attempt and took it off. Back to the drawing board...
If you look under the chassis rails you'll find the mounts, complete with welded on nuts. They're at a guess 6mm so probably wont take too much weight, but they'd do for something mainly cosmetic.
Pinched some photo's from difflock, so credit goes to them for this and it isn't mine, it's pretty much a how to and shows where to mount it really well using what's already there
Attachment JimnyFrontBashPlate001.jpg not found
Attachment JimnyFrontBashPlate002.jpg not found
Attachment JimnyFrontBashPlate003.jpg not found
Attachment JimnyFrontBashPlate004.jpg not found
Attachment JimnyFrontBashPlate005.jpg not found
Attachment JimnyFrontBashPlate006.jpg not found
Attachment JimnyFrontBashPlate007.jpg not found
Last edit: 15 years 2 months ago by SPC5838.
- renard38
15 years 2 months ago #21363
by renard38
Replied by renard38 on topic Re: Front Bash Plates
- ooky_123
15 years 2 months ago #21376
by ooky_123
Replied by ooky_123 on topic Re: Front Bash Plates
I looked into this too ... the mounting looks easy .. I have many doodles of things I want made for the Jimny as soon as I can find a fabricator local to me... Side bars, rear bar, front bars ... bash plate.
even started to lok at a swing away rear wheel carrier mounded to the chassis ..
Time to create page: 0.096 seconds
