TYRE SIZES
- Chelmo
15 years 2 months ago #21025
by Chelmo
TYRE SIZES was created by Chelmo
Could anyone tell me.......will General Grabbers A/T 205 75 r15 fit onto a standard unmodified 2003 Jimny.
Thanks........
Thanks........
- ZookFastback
15 years 2 months ago #21026
by ZookFastback
Replied by ZookFastback on topic Re: TYRE SIZES
Yep
- adamatdraycott
15 years 2 months ago - 15 years 2 months ago #21027
by adamatdraycott
Replied by adamatdraycott on topic Re: TYRE SIZES
Yes, presuming they are the same size as the AT2
No trimming required at all.
AT2:
They slightly improve the ride, but the difference is minimal. Grip is reduced in the wet, but fine if you'r careful on wet roadabouts. Not overly sure about pressures, running mine at 25ish and they seem ok.
Prices have risen over the last month. I bought mine at exactly the right time, saving myself £75 (last check)
I purchased five for £62 each, about 2months ago
AT:
Supposed to be slightly quieter (to EU standards), and look less agressive. Can be had for £65ish.
AT2:
AT:
Last edit: 15 years 2 months ago by adamatdraycott.
15 years 2 months ago - 15 years 2 months ago #21036
by Halford
Replied by Halford on topic Re: TYRE SIZES
originally set mine for tarmac at 23/26 have since changed to 24/27 - I've noticed a huge improvment in ride, harsh crashing over bumps/holes has gone, now simply thuds, much more acceptable. Handling also greatly improved, much better grip, my wet handling has significantly improved.
Adam, were your old tyres actually Dueler HT694's, although my rears only had 3mm (whilst fronts had 7mm) so maybe that's why they were sooooo bad when wet.
check out FoxTrots comments here
:pinch: The grabber AT2's have gone up nearly £90 for 5 fitted via BlackCircles since I got mine last month and the new AT's at most places are close to their RRP £109.26 but TyreTraders have the new GENERAL 205/75R15 97T GRABBER AT at £ 66.60 (4 off delivered for £279.84)
If money's tight you'd only need to get 4 of the new style AT's as future availability isn't an issue, personally, I'd print out the tyretraders quote for 4 off at £279.84 and take it to a local tyre shop and ask them to match the quote (+ their fitting charge obviously)
Last edit: 15 years 2 months ago by Halford.
Time to create page: 0.086 seconds
