Headlight wiring/adding highbeams
- Dutchjimny
15 years 2 months ago #21002
by Dutchjimny
Headlight wiring/adding highbeams was created by Dutchjimny
- dirtydogz
15 years 2 months ago - 15 years 2 months ago #21006
by dirtydogz
Replied by dirtydogz on topic Re: Headlight wiring/adding highbeams
On my 02 soft top the colours are red 56A, red+white56B, white+blue31
The numbers are on the plug that go on to the headlight bulb.
Hope this helps
DIRTYDOGZ
Hope this helps
DIRTYDOGZ
Last edit: 15 years 2 months ago by dirtydogz.
- Dutchjimny
15 years 2 months ago #21008
by Dutchjimny
Replied by Dutchjimny on topic Re: Headlight wiring/adding highbeams
Thank you! i guess i only need 56A? And should i fuse the + from the battery? theres no fuse in the hella wire kit if so, how many AMPS would it be? there are 2 H3 55w halogenbulbs
- Adamski
15 years 2 months ago #21010
by Adamski
I would fuse the + from the battery to be safe. 2x 55w lights at 12v will draw 4.58amps.
Replied by Adamski on topic Re: Headlight wiring/adding highbeams
Dutchjimny wrote: Thank you! i guess i only need 56A? And should i fuse the + from the battery? theres no fuse in the hella wire kit if so, how many AMPS would it be? there are 2 H3 55w halogenbulbs
- dirtydogz
15 years 2 months ago - 15 years 2 months ago #21011
by dirtydogz
You should fit a fuse from the battery to the relay as for the fuse amps I can not help you with this sorry.
Thank you Adamski
Thank you Adamski
- VAXXi
15 years 2 months ago #21012
by VAXXi
Replied by VAXXi on topic Re: Headlight wiring/adding highbeams
Definitely fuse the wire going from battery to relay as close to the battery terminal as possible. 2 x 55 W = 110 W, at 12 V it's around 9.2 amps in total not counting wiring/connector losses. A 10 A fuse should be ok in this case, as both lights are powered by the same cable. If not, use a 15 A one.
To understand better what you're doing there: you're splicing into the existing headlight wiring to control a relay on pins 85/86. When you turn on the beams, they'll switch the relay on allowing current to flow between pins 30 and 87, supplying power to the projectors.
Time to create page: 0.091 seconds
