Jimny missing when warmed up >80 kph
  • lucy
  • Visitor
  • Visitor
26 Aug 2011 13:03 #20905 by lucy
Thanks for the replies. This is my second attempt at sending this message, I think I pressed cancel last time. Well, I have a cd service manual now and noted a diagram about sensors which Martin posted once. -In the Engine & Emission control system/ Ignition system sections.:blink: Well there are a lot of sensors and some harder to get at it it seems. Which would be relevant sensor connector terminals to start to clean considering the problem of the engine 'missing' at speed? I have read a bit but there is a fair bit to it.Thanks again and cheers!
Lucy
  • ZookFastback
  • Visitor
  • Visitor
26 Aug 2011 17:59 #20918 by ZookFastback
Replied by ZookFastback on topic Re: Jimny missing when warmed up >80 kph
I'd suggest doing the simplest things first. Pull out the spark plugs and check for fouling, clean and re-gap. Make sure that you tighten up as per the manual (about 1/2 turn from 1st resistance) and then check that the connections are all firm. I always spray all connections with Inox to ensure good connections and easy removal next time. Disconnect wiring to sensors one at a time and clean with steel wool then spray and reconnect. Give your car a run and see how it goes, you might not have to pull sensors out.
  • lucy
  • Visitor
  • Visitor
03 Sep 2011 11:44 #21253 by lucy
Replied by lucy on topic Re: Jimny missing when warmed up >80 kph
Thanks for the useful info Ian. Spark plugs have been checked. Do you need to disconnect the negative terminal from the battery before disconnecting the wiring ie. connectors, from the sensors? Just wondering. A friend unclipped a couple of connections to show me how easy they were to pull off, but we didn't disconnect the battery terminal then. Thanks again.
  • zaine
  • Visitor
  • Visitor
08 Sep 2011 10:04 #21507 by zaine
Replied by zaine on topic Re: Jimny missing when warmed up >80 kph
cam and crank sensors are the usual suspects
my last jimny did it once warm, revs bounce / misses; let it cool down abit and away it went fine
Time to create page: 0.128 seconds
