Rear Window wash leaks on a slope ? cure.
- adamatdraycott
26 Aug 2011 09:07 - 26 Aug 2011 09:12 #20899
by adamatdraycott
Replied by adamatdraycott on topic Re: Rear Window wash leaks on a slope ? cure.
Halfrauds do a small inline non return valve, about £2.50
EDIT: www.halfords.com/webapp/wcs/stores/servl...-1_categoryId_165746
3/16" or about 8mm sounds about right?
Last edit: 26 Aug 2011 09:12 by adamatdraycott.
- NJF
28 Feb 2014 14:25 #106482
by NJF
Replied by NJF on topic Re: Rear Window wash leaks on a slope ? cure.
There is a very simple solution to this that works very very well. When I set about replacing the non return valve as discussed I had to buy a pack of two. Use both! Fit two non return valves straight after each other about an inch apart. I thought the resistance would stop it working or reduce the flow, but it doesn't. Stopped the leaking and it hasn't leaked since. You will not believe how long your washer bottle lasts after doing this.
- Thank you received: 115
28 Feb 2014 14:54 #106485
by maverick
Jalapeño, IISY?
Replied by maverick on topic Re:Rear Window wash leaks on a slope ? cure.
The NRV has an arrow on it, which way round is it??
Jalapeño, IISY?
- The Snail
14 Dec 2017 00:34 #187428
by The Snail
Replied by The Snail on topic Rear Window wash leaks on a slope ? cure.
I was wondering if I can put the valve at the same tube but into the engine bay, not at the rear door. Theoretically, should be the same thing. The idea is not to remove the door plastic cover. Thank you!
- steelman57
15 Dec 2017 21:18 #187510
by steelman57
Replied by steelman57 on topic Rear Window wash leaks on a slope ? cure.
I did exactly that - 2 in-line valves near the washer bottle. Worked great!
- The Snail
15 Dec 2017 22:49 #187511
by The Snail
I already ordered a new one from ebay for £2. I will do the job soon, hopefully. Thanks for the reply.
Time to create page: 0.404 seconds
