Rear Window wash leaks on a slope ? cure.
- teafortwo0789
25 Aug 2011 15:07 #20874
by teafortwo0789
Rear Window wash leaks on a slope ? cure. was created by teafortwo0789
When I park the Jimny nose up on a slope, the rear washer leaks and siphons off all the washer fluid, leaving me with an empty bottle.\!!!
On a previous topic I complained at the rather small washer bottle. Any thoughts as to the cure / cause?
25 Aug 2011 15:38 #20876
by facade
Replied by facade on topic Re: Rear Window wash leaks on a slope ? cure.
There should be a spring loaded one way valve near to the rear nozzle, to stop the fluid running back to the tank, it takes a bit of pressure to let the fluid out, to stop the jet dribbling.
Sounds like it is missing or the spring has given up.
I dont know exactly where it is I'm afraid....
- doncarlyon
25 Aug 2011 17:46 #20881
by doncarlyon
Replied by doncarlyon on topic Re: Rear Window wash leaks on a slope ? cure.
Mine was doing this aswell...
I just disconnected it at the bottle.
- teafortwo0789
25 Aug 2011 20:47 #20890
by teafortwo0789
Replied by teafortwo0789 on topic Re: Rear Window wash leaks on a slope ? cure.
Makes sense. From what you say it sounds as though there will be a valve inside the water jet 'rod' / nozzle. I'll take it to bits and have a look and report back.
Many thanks. Tony aka (teafortwo0789)
26 Aug 2011 06:34 #20897
by facade
I would have thought it was in inline valve, if there isn't one, perhaps you could get one from a motor factors and fit it inside the rear door.
The following user(s) said Thank You: teafortwo0789
- Thank you received: 115
26 Aug 2011 08:59 #20898
by maverick
Jalapeño, IISY?
Replied by maverick on topic Re: Rear Window wash leaks on a slope ? cure.
the 'valve' is in-line at the rear window wash/wipe ... little pipe behind rear door cover.. cost me a few quid from Suzuki.
Jalapeño, IISY?
