Immobiliser cut in
20 Jul 2011 05:07 #19221 by rusty spanner
Is there any way getting around the immobiliser on my 2001 y reg jimny as padlock light on and will not start
20 Jul 2011 05:23 #19222 by mlines
Replied by mlines on topic Re: Immobiliser cut in
Have you tried disconnecting the battery for a few minutes and then re-connecting it?
20 Jul 2011 05:30 #19223 by rusty spanner
Yes don that and the padlock light stays on
  • ZookFastback
20 Jul 2011 05:49 #19224 by ZookFastback
Replied by ZookFastback on topic Re: Immobiliser cut in
Is your transponder working? Does the little light come on as flat battery in transponder will not let you disable immobiliser. Always start with the simplest solutions ;)
  • ZookFastback
20 Jul 2011 05:50 #19225 by ZookFastback
Also. if the trnsponder batteries get shaken loos, you might have to reset it, the methodology is set out in the manual.
20 Jul 2011 06:00 #19227 by rusty spanner
Only have a plane key that that has no buttons on or any thing but did start the jeep befor I fitted a new engine the bat was off for about a week I have spark and fuel to the fuel rail but 99.9 % sure the injectors not working so would def say immobiliser ?????
Time to create page: 1.049 seconds
