doors rattle
  • zammit
  • Visitor
  • Visitor
07 Jul 2011 05:25 #18670 by zammit
doors rattle was created by zammit
hey guys
my jimnny doors rattle like crazy asoon as i come accross any slight bump in the road.
does anyone elses do this?
and what can i do to fix it its driving me crazy
cheers
zammit
07 Jul 2011 06:32 #18673 by mcjimny
Replied by mcjimny on topic Re: doors rattle
Its not just the doors!!!
My doors do rattle and the interior light flickers on big hits!
  • zammit
  • Visitor
  • Visitor
07 Jul 2011 07:02 #18674 by zammit
Replied by zammit on topic Re: doors rattle
hahaha mine dont do that..... yet:unsure:
  • VAXXi
  • Visitor
  • Visitor
07 Jul 2011 09:13 #18679 by VAXXi
Replied by VAXXi on topic Re: doors rattle
I've done some soundproofing on my Jimny, as it's driven for quite long distances it's important to get every annoying noise out of the cabin and have a comfortable ride.
If you've removed the door trim at some point, it's possible to have some broken or unseated clips which allow rattling. Fix: remove trim and rearrange the clips, replacing the broken ones.
You can also have some cables which are rattling around. Fix: wrap cabling in soft adhesive sponge, so they won't hit metal anymore.
If you still have noises, try checking the lock mechanism for play.
And of course, check that you don't have any coins in the door pocket :laugh:
  • zammit
  • Visitor
  • Visitor
07 Jul 2011 09:43 #18681 by zammit
they noise i get is more of a banging noise. as if the doors arnt closing properly
  • Keefe
  • Visitor
  • Visitor
07 Jul 2011 09:47 #18682 by Keefe
Replied by Keefe on topic Re: doors rattle
Try moving the striker plate (in the body opening) either in or out, probably inwards, a little bit. Might pull the door in tighter when you close it? Mine did this and this cured it.
Having said that, it wasn't as successful on the back door 'knocking'. This was cured by adjusting the rubber 'supports' in the door.
hth
K :)
  • zammit
  • Visitor
  • Visitor
07 Jul 2011 09:50 #18683 by zammit
thanks for that keeth
the stricker plate have counter sunk locating holes though dont they wont this make it hard for me to move it back?
07 Jul 2011 13:01 #18687 by mcjimny
VAXXi wrote: it's important to get every annoying noise out of the cabin and have a comfortable ride.
Exactly why i leave the wife and kids out of it!
  • zaine
  • Visitor
  • Visitor
07 Jul 2011 13:06 #18689 by zaine
Replied by zaine on topic Re: doors rattle
lmao :)
  • Keefe
  • Visitor
  • Visitor
07 Jul 2011 15:39 #18697 by Keefe
I found I got just enough movement to stop the knocking.
Also, try the lock mech in the door, there's a little movenment in that as well.
  • jimny5
  • Visitor
  • Visitor
07 Jul 2011 16:18 #18698 by jimny5
Replied by jimny5 on topic Re: doors rattle
zammit wrote: thanks for that keeth
Im sure they do move,most cars look like that, the adjustment is behind on the nuts.
Mark around it to show original postion then losen them and it should move up, down and in out.
  • teafortwo0789
  • Visitor
  • Visitor
18 Jul 2011 16:11 #19128 by teafortwo0789
Replied by teafortwo0789 on topic Re: doors rattle
Another annoying rattle is the glove compartment. On mine the left outer upper corner rattled against the surround and there doesn't seem to be any way to adjust it by way of adjustment of the catch..
1. So I used a hot air gun to heat the outer corner until it softened(went plastic) and then bent it inwards.
2. Held it in position until it went cool.
3. At that point it had set in new position.
4. When I now shut the lid it acts as a spring to stop the rattle.
Time to create page: 0.159 seconds
