Washer Bottle - a bit small - any suggestions
  • teafortwo0789
  • Visitor
  • Visitor
09 Jun 2011 17:21 #17584 by teafortwo0789
Washer Bottle - a bit small - any suggestions was created by teafortwo0789
The washer Bottle - it is a bit small.
Does anyone have a suggestion as to a suitable larger replacement?
Thank you
10 Jun 2011 19:00 #17622 by kirkynut
Have a look at this:
shop1.actinicexpress.co.uk/shops/Rat_Spo...24cc396c2b69770f6558
You'd have to have a measure up and maybe call them to get the dimentions of the larger one.
It might be possible to connect them together via a T piece that they might be able to supply or that Halfords sell and have two.
Or take a trip to a scrap yard and see what you can find.
They are not that small though are they??? Mine's not a daily drive but have been on week long greenlaning holidays and didn't have to fill it up too regularly.
  • doncarlyon
  • Visitor
  • Visitor
11 Jun 2011 12:38 #17638 by doncarlyon
Replied by doncarlyon on topic Re: Washer Bottle - a bit small - any suggestions
Dont look that small to me... must be a good few litres?
13 Jun 2011 09:19 - 13 Jun 2011 09:21 #17704 by Johnniehec
Something like this maybe?:huh:
Attachment overload.jpg not found
Seriously though what kirkynut said or a trip to the scrapyard and see what you can find.
John.!!!
Last edit: 13 Jun 2011 09:21 by Johnniehec.
  • lukeyblunt
  • Visitor
  • Visitor
13 Jun 2011 09:21 #17706 by lukeyblunt
Replied by lukeyblunt on topic Re: Washer Bottle - a bit small - any suggestions
Thanks for reminding me ! - need to refill mine. :lol:
  • teafortwo0789
  • Visitor
  • Visitor
13 Jun 2011 15:55 #17722 by teafortwo0789
Replied by teafortwo0789 on topic Re: Washer Bottle - a bit small - any suggestions
B) Thank you for the suggestions. I'm used to a VW which has a massive bottle but it is tucked partially under the wing. I want to avoid cutting the inner wing The VW bottle also supplies water to the headlamp washers and that was going to be my next step on the Jimny.
I've also just seen a really good protective headlamp cover. The item was made in Australia and conceptually a good mod for the Jimny. I'm going to source some Polycarbonate (Lexan - GE) which is almost indestructible. It easily is easily bent using a heat gun and can be drilled and a tap threaded for scews. Once I've made a couple I'll post a design on this site. If I'm right then almost anyone could make them for themselves.
13 Jun 2011 17:31 #17734 by Halford
Hi Tony
is this what need :blink:
  • supergaz
  • Visitor
  • Visitor
13 Jun 2011 17:58 #17738 by supergaz
What appears little in a shogun boot, is going to drown a jimny :-)
  • Municipal Waste
  • Visitor
  • Visitor
16 Jun 2011 16:07 #17890 by Municipal Waste
Replied by Municipal Waste on topic Re: Washer Bottle - a bit small - any suggestions
supergaz wrote: What appears little in a shogun boot, is going to drown a jimny :-)
That thing is probably bigger than the actual 'boot' in a Jimny. :S
  • supergaz
  • Visitor
  • Visitor
17 Jun 2011 14:19 #17943 by supergaz
Looks like the rear seats will still be useable, I think its great the way they hide under the floor, or if they are up then there is a great big hidden storage compartment. Such a shame the shogun went independent suspension on the rear and the loss of the ladder frame chassis. However I find it's a great tow truck for my jimny. And rear diff lock on the switch as standard!
29 Oct 2011 14:16 #24714 by Halford
trextr7monkey just suggested CBS online for v8dougie's door switch, checked out their link and spotted a 3 lt Windscreen Washer Bottle Kit £48 :pinch:
  • Dunkspeed
  • Visitor
  • Visitor
29 Oct 2011 15:50 #24745 by Dunkspeed
What about...
www.europaspares.com/product/95/13519/WI...TLE_KIT___SFWB_.html
Or you could double the existing system up.
Time to create page: 0.170 seconds
