Off road driving technices.
- Fingers
30 May 2011 05:45 - 30 May 2011 05:48 #17077
by Fingers
Off road driving technices. was created by Fingers
Hi, I've take my jimny to an off road pay n play site yesterday. The ground wasn't very flat at all.
Anyway. Driving style/ technic. What's best??
I found 1st gear low was still a bit high. Even at idle
the truck was running away. My wheels/tires are only 215/80/r15
and so I found myself doing alot of clutch work. But this is gunna wear the clutch really fast.
So any advice on driving style or transfer box upgrades
it would be cool if you. Could get a transfer box that lowered , low range and left high range alone.
Any advice I'd be thankful for. Jon
Last edit: 30 May 2011 05:48 by Fingers.
- Bannerbrother
30 May 2011 06:34 #17078
by Bannerbrother
Replied by Bannerbrother on topic Re: Off road driving technices.
I also found that the low box isnt that low. There is a rock lobster conversion (80% lower than standard) but its a daily driver so woundered how this would effect the high box, as i wouldnt want to comprimise the economy.
- Municipal Waste
30 May 2011 06:58 #17080
by Municipal Waste
Replied by Municipal Waste on topic Re: Off road driving technices.
Changing the ratio of your transfer box shouldn't do anything to the daily drive as far as I'm aware as you're just altering the ratio of the low box.
If you're changing the size of the tyres on the car then you'll likely need to alter the low box anyway as you've raised the gearing by going larger on the tyres.
Personally I'm running the standard 205/70s still and the low box is a bit low even!
One pointer I can give you to off road driving is at all times look into the distance and plan a route that won't make your car tip left or right as it can start to get very dangerous. If you try to get up something steep and fail, don't hit the brakes too hard or pull the handbrake, get it into reverse as fast as you can and use the clutch because the Jimny is so short you'll easily go over backwards!
- rajsuzuki
30 May 2011 10:51 - 30 May 2011 10:56 #17092
by rajsuzuki
Replied by rajsuzuki on topic Re: Off road driving technices.
I don't know of any conversion which would only lower the low ratio and leave the high ratio as standard
ÂÂÂ
Reduction Ratio
4:1
5:1
6:1
8:1
these are the different ratio you can reduce to 8:1 been for severe winch events and with a top speed of walking pace .
when I put mine in it brought my top speed down to 55 to 58 mph with a really good bank and a tail wind I can get NOW GET READY FOR THIS TO 63mph
ÂÂÂ
Reduction Ratio
4:1
5:1
6:1
8:1
Last edit: 30 May 2011 10:56 by rajsuzuki.
- Fingers
30 May 2011 13:21 #17097
by Fingers
Replied by Fingers on topic Re: Off road driving technices.
Where could you get any reduction kits from??
- renard38
30 May 2011 14:48 #17098
by renard38
Replied by renard38 on topic Re: Off road driving technices.
yes, the low box isnt that low, this is why i put a transfert box from a SJ 413 with a 4.16
In 1st low range : :silly:
A+
A+
Time to create page: 0.106 seconds
