Help...Unidentified part!
  • v8dougie
15 years 5 months ago #16971 by v8dougie
Help...Unidentified part! was created by v8dougie
After successfully changing the timing belt on my Jimny (very easy to do!), I was finishing off tightening the lower supporting bolt for the alternator, and I found this just loose resting on top of where the bottom of the radiator sits. Does anyone have any idea what it is or where it has come from? I have taken the car for a drive and all still works fine.
It looks like it has broken/sheared off from somewhere, but the break has a bit of rust and crud on it, so does not look massively recent. Any help much appreciated!
Cheers
Phil
  • Keefe
15 years 5 months ago #16975 by Keefe
Replied by Keefe on topic Re: Help...Unidentified part!
Without going to the garage and looking at mine, I'd say it was one of the front tie down points that had been cut off or burnt off.
K :-)
  • srcars
15 years 5 months ago #16976 by srcars
Replied by srcars on topic Re: Help...Unidentified part!
Again without looking if not a tie down point as above it could be an engine lifting eye (do they still fit them ?)
  • v8dougie
15 years 5 months ago #16977 by v8dougie
Replied by v8dougie on topic Re: Help...Unidentified part!
Thanks for the super speedy responses. Sounds plausible, would someone be able to have a look and see if/where theirs is attached. Bit concerned as the vehicle is totally standard, and never been off road (will change soon!) so not sure why it would be broken.
Cheers
Phil
  • srcars
15 years 5 months ago #16979 by srcars
Just been out and had a look and this is what I think it is, Strange part to come off though :unsure:
  • v8dougie
15 years 5 months ago #16980 by v8dougie
That looks like him...very strange part to come off like you say. As far as I know the engine hasn't been out, and I assume it is an engine anchor point.
I shall check when I get home, cheers for the help & pic!
Phil
Time to create page: 0.109 seconds
