Lift blocks
19 Apr 2011 08:27 - 19 Apr 2011 08:28 #15227 by Johnniehec
Lift blocks was created by Johnniehec
Can someone tell me the diameter of the body lift blocks, aluminium or nylon, that that are supplied in the various body lift kits? I'm going to DIY, Aberdonian in me again!, along the lines of the Eco lift topic, but with blocks, recon I can get about 25-30mm with the standard bolts, buy a length of nylon from www.directplasticsonline.co.uk/Nylon_6_Rod.html
cut it, drill it (may have to split and glue it rather than lift 5ins plus to clear the bolts) and cut the rubbers down if required. I just need to know what diameter rod to order, I think I saw mention of it in a thread some where but I can't find it.
I'm going to be fitting sill bars, I've got them cut and bracketed ready to fit but obviously want to do the body lift first so I don't have to move them.
Cheers,
John.
Last edit: 19 Apr 2011 08:28 by Johnniehec.
19 Apr 2011 10:59 #15234 by X8GGY
  • srcars
  • Visitor
  • Visitor
19 Apr 2011 17:18 #15250 by srcars
Replied by srcars on topic Re: Lift blocks
Yep 50mm, but in my opinion you would be much better off buying a propper kit with the sleeved bolts. I belive there is a cheap £30 ish kit on e-bay which comes with lift blocks and long bolts which may work out like a good deal for if you decide to go that way.
The sleeved bolts which come in the more expensive kits are worth their weight in gold though and apart from the steering and transfer box make the kit a bolt on job that can be done in a few hours single handed. The problem with a DIY job is that you have to remove the original captive body mounting bolts to fit your extended nut and bolt set up. Maybe somebody will confirm but I seem to think that some of them maybe in double skinned panels meaning you will have to cut through the upper skin to gain access to drop the bolts through.
Which ever way you go I think Its a great mod and I am very happy with the end result.
Rich
  • bertbuckie
  • Visitor
  • Visitor
19 Apr 2011 17:31 #15252 by bertbuckie
Replied by bertbuckie on topic Re: Lift blocks
I think Adam bought one of the cheap ebay kits and said pay out the extra...... not worth the hastle!
John, your as tight as me haha
19 Apr 2011 18:00 #15254 by mlines
Replied by mlines on topic Re: Lift blocks
With the cheap kits they get you to drill through the captive bits and bolt through :0
  • vitara_mad
  • Visitor
  • Visitor
19 Apr 2011 18:46 #15255 by vitara_mad
Replied by vitara_mad on topic Re: Lift blocks
if you going to do it do it right & get a decent kit & avoid the cheap so called body lift kits on ebay there not even worth the postage cost
Time to create page: 0.139 seconds
