Whats this?
- doncarlyon
16 Apr 2011 14:40 #15131
by doncarlyon
Whats this? was created by doncarlyon
16 Apr 2011 14:55 #15132
by facade
Replied by facade on topic Re: Whats this?
Oil coming from the halfshaft is escsping from the swivel housing.
You need to check the swivel bearings (kingpins) for play, (most likely there will be) then change
Top & bottom swivel bearing
Half shaft oilseal
Both these come to about £23 from Bigjimny Shop
You most likely will need a new swivel housing seal, these are about £25 off eBay
So £50 will get it sorted.
There are some guides on here to help with fitting.
Half shaft oilseal
- bluejimny
16 Apr 2011 15:23 #15133
by bluejimny
Replied by bluejimny on topic Re: Whats this?
yes as above matey!
- doncarlyon
16 Apr 2011 15:51 #15135
by doncarlyon
Replied by doncarlyon on topic Re: Whats this?
Ok cool... thanks guys!
Will get it looked it, im off work next week anyway.
- Keefe
16 Apr 2011 16:26 - 16 Apr 2011 16:27 #15138
by Keefe
Replied by Keefe on topic Re: Whats this?
Last edit: 16 Apr 2011 16:27 by Keefe. Reason: spulling mistook
- myers647
16 Apr 2011 16:59 #15139
by myers647
Replied by myers647 on topic Re: Whats this?
Hi mate it will probably be the swivel joint seal, this is a ten minute job to change. Just make sure you remember which way the three seals go when you put them back on you will know what I mean when you take it off.
Have a look on the HOW TOO part abou how to change the KING PIN bearings this shows the seal.
Good look
James
Good look
James
