Manual Hubs
- doncarlyon
06 Apr 2011 06:45 #14583
by doncarlyon
Manual Hubs was created by doncarlyon
Which ones would you go for?
SJ ones dont seem to come up for sale very often and need an adaptor plate... or AVM ones which cost more but would be brand new and dont need an adaptor?
- ooky_123
06 Apr 2011 07:57 #14589
by ooky_123
Replied by ooky_123 on topic Re: Manual Hubs
Personally, SJ Hubs are just as good. As long as you make sure you get the cone washers that come with it, there is nothing wrong with going this route.
If you have the cash, I suppose the others would give you peace of mind
06 Apr 2011 08:02 #14591
by Obarno
Replied by Obarno on topic Re: Manual Hubs
Having had both I would go for the original SJ ones - Aisin - they seem very strong and will probably be cheaper even with an adaptor ring from Martin. As Ooky says though make sure you get the cones as they are difficult to find and probably expensive. From Martin you get an adaptor ring and new bolts so you only need the cones.
- Keefe
06 Apr 2011 08:15 - 06 Apr 2011 20:30 #14594
by Keefe
Replied by Keefe on topic Re: Manual Hubs
What are the cone washers that Milners sell, are they not the same size?
Came across them while browsing, if I remember right, they are in Toyota Surf section.
K
www.milneroffroad.com/categories.asp?cID=10991&p=2
K
Last edit: 06 Apr 2011 20:30 by Keefe. Reason: Added link
Time to create page: 0.085 seconds
