loud screeching noise continued
  • george
25 Mar 2011 06:53 #14017 by george
loud screeching noise continued was created by george
after good advice from various folk i have come to the conclusion that my problem is down to diff,front output bearing on transfer box,or cv joint.has anyone got any suggestions on how to detect a problem with these three without stripping them down first,will i have to take the transfer box out to renew the bearing,heres hoping.
25 Mar 2011 07:38 #14021 by kirkynut
Are you sure its not the uj's on the prop seized. Once Martin suggested this I would've put my money on it and it would've stopped once you took the hubs off. A lot more likely and easier to fix.
Have you taken the prop of to see how they move?
25 Mar 2011 17:28 #14061 by facade
Something has to come apart.
Using my crystal ball I would say that there is a wheelbearing gone, one of the hubs hasn't disengaged, and the last 20,000 miles at 70mph with only one halfshaft driving has damaged the diff.
You are going to have to get underneath and start turning things to see what has gone.
Take the propshaft off first, and try spinning the diff flange. You can engage the hubs and drive it with no front propshaft if you like.
Erm, there is oil in the front diff?
  • george
25 Mar 2011 18:35 #14064 by george
Replied by george on topic Re: loud screeching noise continued
i do not think its the wheel bearings these would surely vibrate with the hubs off,but no noise was detected when i did this,as for the prop i checked these first and all looks ok.
25 Mar 2011 19:10 #14067 by kirkynut
I agree in taking the front prop off and checking it once it's off - there is no substitute in checking than to take it off to check it properly. The UJ's should flop and seem free but not have play. I suspect they won't and this will be the issue.
As facade says - then give it a drive without it on and turn the diff by it's flange by hand and see how it feels and the transfer box flange by hand to see how it feels.
I imagine you'd feel a wheel bearing or at least hear it grumble as you spin it with the wheel on and the car on a jack.
It's a case of trial and error really.
You have checked the diff oil level though haven't you???
  • george
27 Mar 2011 06:22 #14111 by george
i have checked the diff oil in both thats ok.i will try it without the prop but on inspection it does look fine.i just realised my mistake as i am asking technical stuff on the chat section,will sort it.
Time to create page: 0.103 seconds
