Trailmaster 2" kit
21 Mar 2011 14:36 - 21 Mar 2011 14:48 #13741 by dirtydogz
Replied by dirtydogz on topic Re: Trailmaster 2" kit
Attachment b4v-springspacers41_2011-03-21.jpg not found
BITS4VITS spring spacers+BIG JIMNY rear shock brackets, on jimny stock shock.
I use my jimny 85% on the road.
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 21 Mar 2011 14:48 by dirtydogz.
  • Little Terror
  • Visitor
  • Visitor
21 Mar 2011 14:42 #13742 by Little Terror
Replied by Little Terror on topic Re: Trailmaster 2" kit
I've used spacers before on my vitaras and they make the ride very harsh so I want a proper lift kit,thanks anyway.
21 Mar 2011 14:46 #13743 by dirtydogz
That OK mate good luck.
DIRTYDOGZ B)
  • biggaz
  • Visitor
  • Visitor
21 Mar 2011 14:47 #13744 by biggaz
Replied by biggaz on topic Re: Trailmaster 2" kit
what martin said is very much true, your gonna have to see what people have managed to fit then take the plunge and go safe or go big but be prepared if they dont fit as you would like..
Very much trial and error, 235/75 are a nice safe bet. At tong, a lad we went round with had a 2" lift with NO body lift and ran 30/9'5 kumho kl71 without much bother.. dont know if they rubbed but only slightly if they did?
  • supergaz
  • Visitor
  • Visitor
21 Mar 2011 18:24 #13747 by supergaz
Replied by supergaz on topic Re: Trailmaster 2" kit
Little Terror wrote: Thanks for the info and when I get my jimny I will give you a call also are 235/75/15 29" high.
I was going to get the 3" ORA kit but after reading how going over 2" on the spring lift can throw all the steering geometry out and needing castor correction ect I am now going to stick with 2".
I have seen the jimny trailmaster advert on YouTube and that seems to handle very well.
The ORA kit includes all the caster correction arms and panhard rods so no worry about steering geometry. Its the best package in mho, if you can afford it all at once. Or I should say I wish I had saved up enough to go the full ORA route from the start. Rob from ORA did amazing deals at the TOR show, its worth waiting for the next one! I'm planning on parts already to get from the next show.
  • Little Terror
  • Visitor
  • Visitor
21 Mar 2011 19:50 #13760 by Little Terror
No doubt ORA is good stuff but i would rather do it allot cheaper so ive got money to spend on the rest of my project,after all im only going to be using it for green laning and i want to do the lot for around fifteen hundred and the ORA 3" kit would have used all that,anyway ive done my research and in my mind the Trailmaster 2" kit is the way to go without causing to many other problems also i want to do it all myself because thats half the fun for me.Thanks for the advice on here in a bit you will be calling me a jimny pro.
Time to create page: 0.159 seconds
