wheel arches
  • biggaz
  • Visitor
  • Visitor
18 Mar 2011 23:29 #13570 by biggaz
Replied by biggaz on topic Re: wheel arches
trextr7monkey wrote: We have made right angle ABS plastic wing extensions (not on a Jimny) by bending a strip over a hot wire bender, the ends can be rounded off and some U trim applied it is delightful stuff to work with and can be shaped ith a hot air gun, too. Fastened on with large rivets
i129.photobucket.com/albums/p211/trextr7...0pieces/S4010128.jpg
i129.photobucket.com/albums/p211/trextr7...0pieces/S4010130.jpg
this shows front and back extensions
i129.photobucket.com/albums/p211/trextr7...y/ninja/S3400036.jpg
hth
Mike
That looks superb!
  • gazert
  • Visitor
  • Visitor
19 Mar 2011 00:54 #13579 by gazert
Replied by gazert on topic Re: wheel arches
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
darthloachie wrote:
gazert wrote:
vitara_mad wrote: you could fit the +2" landrover arches adamjimny has done this & it looks well
I have just put 10,5 31x15 on mine and need arches but those defender arches are stupid money!!!
sorry to hi jack. Any one got any other ideas?
here you go
That ain't wide enough. Thanks Gaz
  • oxford_bloke
  • Visitor
  • Visitor
19 Mar 2011 06:33 #13580 by oxford_bloke
Replied by oxford_bloke on topic Re: wheel arches
cheers for the response guys
but the problem lies with the fact a jimny wing is only about 2 or 3mm thick and with the plastic inner arches removed it leaves a big void under the wheel arch.
so maybe if i made some L shaped brackets to fit the rubber it may work.
any other ideas are very welcome
cheers
  • dave t
  • Visitor
  • Visitor
19 Mar 2011 11:10 #13605 by dave t
Replied by dave t on topic Re: wheel arches
you could do what i did with belt rubber just make it as wide as you want very strong and stiff it would cope withe been stuck out a foot no problem, bolted to the inside of the arches,then sealed with gasket sealent atb dave.
Time to create page: 0.178 seconds
