Wheels...
- little jimny
09 Mar 2011 20:21 #12925
by little jimny
Wheels... was created by little jimny
I've found these wheels advertised cheaply and am thinking about them instead of refurbing my steels. Could someone photoshop these onto a Grove Green metallic Jimny? They are 8x15, ET25 - will the standard 205/70/15s sit OK on them, and will they fit the Jimny without clearance issues?
- darthloachie
09 Mar 2011 20:50 - 09 Mar 2011 20:53 #12931
by darthloachie
Replied by darthloachie on topic Re: Wheels...
they are the same as one of the vitara fat boy alloy design
£35 each bargain!
£35 each bargain!
Last edit: 09 Mar 2011 20:53 by darthloachie.
- little jimny
09 Mar 2011 21:31 #12941
by little jimny
Replied by little jimny on topic Re: Wheels...
It was the price that got my attention! But it's only a bargain if I can use my existing tyres and they fit properly without fouling anything or looking silly, which is where you guys come in, 'cos I can't see the offset stamped anywhere on the steels. The width worries me a bit - 8 inch on these alloys compared to 5.5 inch on the steels.
- vitara_mad
09 Mar 2011 21:39 #12944
by vitara_mad
Replied by vitara_mad on topic Re: Wheels...
shame there not steel :lol:
- biggaz
09 Mar 2011 21:55 - 09 Mar 2011 21:59 #12948
by biggaz
Replied by biggaz on topic Re: Wheels...
Offset is 25.... et25!
Which is fairly high for 8j wheels.... i personally would want to know they wouldnt foul the INSIDE of the arch's/suspension etc.
Whap some spacers on iof they do
The other 5 spokes further along are et (minus) 25, they would be better :evil:
Last edit: 09 Mar 2011 21:59 by biggaz.
- little jimny
10 Mar 2011 06:44 - 10 Mar 2011 06:45 #12958
by little jimny
That's what I'm worried about. I think the offset of the standard steel wheels is ET5, and comparing them on www.willtheyfit.com shows the inner edge would sit much further inside the arch, so does anyone know if there is enough room inside the arch to get away with this?biggaz wrote: .... i personally would want to know they wouldnt foul the INSIDE of the arch's/suspension etc.
How does this work? There's just about enough stud to get the wheel nuts on. Do you have to fit longer studs? Is that an easy job?biggaz wrote: Whap some spacers on iof they do
Looking at those on www.willtheyfit.com shows the inner edge would sit the same as the standard wheel (assuming it is ET5), but they stick out much further so there's a chance they'd stick out past the arch which would be an MOT failbiggaz wrote: The other 5 spokes further along are et (minus) 25, they would be better :evil:
Last edit: 10 Mar 2011 06:45 by little jimny. Reason: spelling!
Time to create page: 0.173 seconds
