DIY steel wheel refurb
- little jimny
01 Mar 2011 21:28 #12371
by little jimny
DIY steel wheel refurb was created by little jimny
Hi, I've just bought a 2002 Jimny that I'm very happy with. The steel wheels are discoloured and quite rusty so I want to refurb them, but on a budget - there are other more pressing things that need addressing (brakes, wheel alignment and a decent service). I'm thinking of sanding down the rust with a wire brush attachment on a drill and then spraying them with smoothrite - anyone refurbed their steel wheels and have any comments?
- Monkey
01 Mar 2011 21:36 #12374
by Monkey
Replied by Monkey on topic Re: DIY steel wheel refurb
Hi mate,
A mate of mine has just refurbed his steel rims.
-If possible get a 5" grinder with a wire wheel and strip the whole lot of the old paint of.
-give the bear steel a light rub with some fine sand paper
-rub the rim down with thinner's before you paint just to get all the dirty out
-and then paint like you normally would a few coats of what ever colour and then a clear coat.
That's long way of doing it but they come up nicely.
- little jimny
01 Mar 2011 21:43 #12375
by little jimny
Replied by little jimny on topic Re: DIY steel wheel refurb
I was thinking grind back the rust then a few coats of silver smoothrite with no lacquer (I'd read that lacquer tends to react wiht the smoothrite), or a couple of coats each of primer, then silver and finally lacquer although that's bit of a long winded way of doing it and I'm not sure I've got the patience!!!! If a couple of coats of smoothrite will give a presentable finish with no rust and no flaking then that 's the way I'll probably go unless htere's anything better out there anyone would recommend.
02 Mar 2011 06:53 #12381
Replied by mlines on topic Re: DIY steel wheel refurb
- little jimny
02 Mar 2011 08:28 #12384
by little jimny
The enamel finish looks really good. Did you brush or spray it?
02 Mar 2011 08:59 #12390
Rattle can enamel from Halfrauds
Time to create page: 0.204 seconds
